VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
How do i know a light weight polyline is symmetrical or not?
1 REPLY 1
yaqiz
315 Views, 1 Reply
Hi All
1 REPLY 1
Hallex
in reply to: yaqiz
Do you mean to check if the pline has constant width for all segments
If so try this out
Option Explicit
Sub doit()
Dim oSset As AcadSelectionSet
Dim oEnt
Dim oPline As AcadLWPolyline
Dim fCode(0) As Integer
Dim fData(0) As Variant
Dim dxfCode, dxfValue
Dim i As Integer
Dim SsetName As String
fCode(0) = 0
fData(0) = "LWPOLYLINE"
dxfCode = fCode
dxfValue = fData
SsetName = "$Poly$"
'Make sure selection set does not exist
For i = 0 To ThisDrawing.SelectionSets.count - 1
If ThisDrawing.SelectionSets.item(i).Name = SsetName Then
ThisDrawing.SelectionSets.item(i).Delete
Exit For
Next i
Set oSset = ThisDrawing.SelectionSets.Add(SsetName)
oSset.Select acSelectionSetAll, , , dxfCode, dxfValue
Debug.Print "Selected " & oSset.count & " polylines"
'Process each polyline
For Each oEnt In oSset
Set oPline = oEnt
On Error Resume Next
If Not IsError(oPline.ConstantWidth) Then
Debug.Print "Polyline " & oPline.ObjectID & " has Constant width: " & oPline.ConstantWidth
Else
Debug.Print "Polyline " & oPline.ObjectID & " has not Constant width"
On Error GoTo 0
Next
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
