VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
How can I show 3D Solid objec's name on isometric view?
4 REPLIES 4
ozkan_0712
618 Views, 4 Replies
Hi. Everybody,
I wrote a program that I can give a name automaticly for all 3d solid objects.
But I want to show a little box on isometric view every names with VBA codes.
I try to show on Attachment.
Thanks for helps..
4 REPLIES 4
I would set the UCS to View, then check the geometric extents of your 3DSolid ==> convert that coordinates (WCS) to UCS and that's where your object is on screen currently and where you can place the text.
Does that be a help for you?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Sorry I don't understand excatly.
Has it got any code to show 3D solid parts?
I want to use VBA.
Thanks for helpss
Seems same for me 😉
I have not attached any code. I just wrote one idea of what I would do in case I want to have "your name" written above a 3DSolid in an isometric view.
Create a text. Use the UCS from the view, that's it.
If you want anything else than a text to write the name of an object then I really don't understand your question.
- alfred -
Alfred NESWADBA
Thanks.
I will  try it.
”Boost
