Hi.
I can use SolidSelection.Item for 3D object's handles and but I can't take 3D object's volumes with SolidSelection.
Then I can put object 's handles(1EE) to a collection.
Can I use SolidSelection to keep my 3D volumes values?
All sub-structure of my program works with SolidSelection Object.
Volume Codes;
For Each tEnt In ThisDrawing.ModelSpace
If TypeOf tEnt Is Acad3DSolid Then
Dim tEntSolid As Acad3DSolid
Set tEntSolid = tEnt
tmpVols1.Add (tEntSolid.Handle & "/" & tEntSolid.Volume)
End If
Next
I can't match with returned result of these codes and SolidSelection.item(i)
End If
Next
Dim i As Integer
Dim strVolume As Double
For i = 0 To lstResults.ListCount - 1
If (Split(tmpVols1.Item(i), "/")(0) = Split(Split(tmpVols1.Item(i), "/")(1), "-")(0)) Then
sList.Add (Split(tmpVols1.Item(i), "/")(0))
End If
Next
Thanks for helps...
Thanks everybody. 🙂 I found the problem that collection's start value is "1" , it must be "0" .
