VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Help, Read and Modify Atributos con basic 6 o vb.net
3 REPLIES 3
DrInfierno
416 Views, 3 Replies
Hola amigos de Autodesk, deseria poder leer los atributos de los bloques y tambien modificarlos
con visual basic 6, tengo varias archivos ,dwg y hay muchos bloques con sus respectivos atributos
los cuales quiero modfiicar manualmente, tengo el Autocad 2012 en español espero me puesan ayudar!!!
Luis Tomasto
SistemasIntegralesTomasto@hotmail.com
3 REPLIES 3
Hallex
in reply to: DrInfierno
I'm not sure if this works in A2012
You may want to try it:
'--------------Code start--------------------
Option Explicit
' ! request references:
' 1. - Microsoft Shell Controls And Automation
' 2. - Windows Script Host Object Model
' 3. - Microsoft Scripting RunTime
' 4. - AutoCAD/ObjectDBX Common XX.X Library !
Private Declare Function SHGetPathFromIDList Lib "shell32.dll" _
Alias "SHGetPathFromIDListA" _
(ByVal pidl As Long, _
ByVal pszPath As String) As Long
Private Declare Function SHBrowseForFolder Lib "shell32.dll" _
Alias "SHBrowseForFolderA" _
(lpBrowseInfo As BROWSEINFO) As Long
Private Type BROWSEINFO
    hOwner As Long
    pidlRoot As Long
    pszDisplayName As String
    lpszTitle As String
    ulFlags As Long
    lpfn As Long
    lParam As Long
    iImage As Long
End Type
Function GetFolder(Optional ByVal Name As String = _
    "Select a folder.") As String
    Dim bInfo As BROWSEINFO
    Dim path As String
    Dim oDialog As Long
    bInfo.pidlRoot = 0& 'Root folder = Desktop
    bInfo.lpszTitle = Name
    bInfo.ulFlags = &H1 'Type of directory to Return
    oDialog = SHBrowseForFolder(bInfo) 'display the dialog
     'Parse the result
    path = Space$(512)
    GetFolder = ""
    If SHGetPathFromIDList(ByVal oDialog, ByVal path) Then
        GetFolder = Left(path, InStr(path, Chr$(0)) - 1) & "\"
    End If
End Function
Private Function getFiles(ByVal RootFolder As String, ByRef FileColl As Collection)
Dim fs, f, item, mystring As String
Dim File As Variant, folder As Variant
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set f = fs.GetFolder(RootFolder)
    For Each File In f.files
        If UCase(Right(File.Name, 4)) = UCase(".dwg") Then
            FileColl.Add File.path
        End If
    Next
    For Each folder In f.SubFolders
        Call getFiles(folder, FileColl)
    Next
End Function
Private Sub ChangeBlocksDBX(dwgFiles As Collection, blkname As String, atag As String, aValue As String)
    Dim oEnt As AcadEntity
    Dim oBlkRef As AcadBlockReference
    Dim oAtt As AcadAttributeReference
    Dim oBlock As AcadBlock
    Dim oLayout As AcadLayout
    Dim vers As Double
    vers = Val(Application.ActiveDocument.GetVariable("acadver"))
    Dim dbxvers As String
    dbxvers = "ObjectDBX.AxDbDocument." & Left(Application.ActiveDocument.GetVariable("acadver"), 2)
    Dim dbxDoc As New AxDbDocument
    Set dbxDoc = ThisDrawing.Application.GetInterfaceObject(dbxvers)
    Dim dwgVar As Variant
    On Error Resume Next
    For Each dwgVar In dwgFiles
    Dim dwgName As String
    dwgName = CStr(dwgVar)
    dbxDoc.Open dwgName
    For Each oLayout In dbxDoc.Layouts
    For Each oEnt In oLayout.Block
    If TypeOf oEnt Is AcadBlockReference Then
    Set oBlkRef = oEnt
    If oBlkRef.EffectiveName = blkname Then
    Dim attVar As Variant
    attVar = oBlkRef.GetAttributes
    Dim i
    For i = 0 To UBound(attVar)
    Set oAtt = attVar(i)
    If oAtt.TagString = atag Then
    oAtt.TextString = aValue
    Exit For
    End If
    Next i
    End If
    End If
    Next
    Next
    dbxDoc.SaveAs dwgName
    Next
    Set dbxDoc = Nothing
End Sub
Public Sub Hola()
Dim blkname As String
Dim atag As String
Dim attvalue As String
blkname = InputBox("Enter a block name:", "Batch attribute change")
atag = UCase(InputBox("Enter an attribute tag:", "Batch attribute change"))
attvalue = InputBox("Enter a new attribute value:", "Batch attribute change")
    Dim strFolder As String
    Dim item As Variant
    Dim FileColl As Collection
    Set FileColl = New Collection
strFolder = GetFolder("Select directory to change attribute") ', ThisDrawing.GetVariable("dwgprefix"))
If strFolder = "" Then Exit Sub
If Right(strFolder, 1) <> "\" Then strFolder = strFolder & "\"
Call getFiles(strFolder, FileColl)
Call ChangeBlocksDBX(FileColl, blkname, atag, attvalue)
MsgBox "done"
End Sub
'-------------------code end ------------------------------
~'J'~
DrInfierno
hi man Problems in...
THISDRAWING ----> variable no reconocida
Tags (1)
Hallex
Man,
This code on pure VBA, I just show you the way
You can to convert it on vb.net by yourself
Take a look at this link it may helps:
http://forums.autodesk.com/t5/NET/VBA-to-VB-net/td-p/3275489
See the very last post
”Boost
