Hi akaCAD,
Almost certainly all this (whatever it actually is) can be done with VBA
code.
However, if you cannot describe uniquely in English (or your native
language to a speaker of that language) what you want then there is
little hope that you could code it, or get some one to code it for you.
Laurie Comerford
akaCAD wrote:
> is there a VBA code that can resolve this problem : Modify the content
> of the current drawing to one block calculate the block area hatch the
> block draw a rectangle which its dimensions are gived by the user (in
> the text box) fill in rectangle this block many times inside this
> rectangle and we have the possibility to put this block where we want
> inside the rectangle show an error message if we place the block and we
> have an intersection between the rectangle and the block thank you in
> advance
