Visual Basic Customization
0 Kudos
Post 1 of 7
Getting Constant Attribute using VB.net
687 Views, 6 Replies
03-20-2012 09:14 PM
Hey guys,
Just wondering how I would be able to grab the block constant attribute by searching via tag.
eg block has a constant attribute 'Color' with value of 'red' and I wish to attain 'red'
I am currently obtaining non constant attributes using:
Dim attRef As AttributeReference = DirectCast(tr.GetObject(attId, OpenMode.ForRead), AttributeReference)
and grabbing the '.textstring' when looking at the '.tag'
How do I go about this with similar logic but pointing to constant attributes?
I have tried searching thoroughly and almost all results for me were in VBA.
Many thanks
The c# statement
[Type] something=...... as [Type]
is not the same as DirectCast() in VB, rather it is similar to TryCast(). You cannot DirectCast() whatever in a block definition into an AttributeDefinition, if it is not an AttributeDefinition.
So, simple change this line:
Dim ad As AttributeDefinition = DirectCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition)
To:
Dim ad As AttributeDefinition = TryCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition)
ADN Support Specialist
67 Kudos
Post 2 of 7
Re: Getting Constant Attribute using VB.net
03-20-2012 10:11 PM in reply to: hakand
Constant attributes are stored as AttributeDefinitions in the BlockTableRecord. They're not stored with the BlockReference because they are constant across all BlockReferences.
Cheers,
Stephen Preston
Autodesk Developer Network
0 Kudos
Post 3 of 7
03-21-2012 06:02 PM in reply to: StephenPreston
Ah thank you for the answer. I'm still trying to get my head around this as there aren't many examples available.
How would I cycle through my blocks and point to a specific constant tag and grab the textstring?
Could anyone please provide an example or something related in vb.net?
Or if anyone could please show how I would implement it into the below code I am currently using, that would be much appreciated.
            Dim idArray As ObjectId() = selSet.GetObjectIds()
            For Each blkId As ObjectId In idArray
                Dim blkRef As BlockReference = DirectCast(tr.GetObject(blkId, OpenMode.ForRead), BlockReference)
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                Dim attCol As AttributeCollection = blkRef.AttributeCollection
                For Each attId As ObjectId In attCol
                    Dim str As String = ((vbLf & "  Attribute Tag: " + attRef.Tag & vbLf & "    Attribute String: ") + attRef.TextString)
                    If attRef.Tag = "COLOR" Then
                        If grouparray.Contains(attRef.TextString) = False Then
                            grouparray.Add(attRef.TextString)
                        End If
                    End If
                Next
            Next
Many thanks,
HD
217 Kudos
Post 4 of 7
03-22-2012 07:24 AM in reply to: hakand
As Stephem has already pointed out, constant attribute is defined in BlockTableRecord (block definition). There is no AttributeReference created in Blockreference if an AttributeDefinition is defined as Constant.
You need to understand
1. AttributeReference is an entitiy created in BlockReference with AttributeDefinition as TEMPLATE, but does not have to be te same as he AttributeDefinition. In fact, you can add AttributeReference to a BlockReference without AttributeDefition.
2. Constant AttributeDefition defined in a BlockTableRecord acts the same as a Text entity in BlockTableRecord. That is, the Attribute will go with all other entities in the block definition into a BlockReference.
So, if you need to get value of a constant atribute, the code would like this (assume you seelcteda BlockReferenece' ObjectId, just off my head, not compiled/tested):
using (Transaction tran=theDatabase.TransactionManager.StartTransaction())
    BlockReference bRef=(BlockReference)tran.GetObject(blkrefId, OpenMode.ForRead);
    BlockTableRecord blk=(BlockTableRecord)tran.GetObject(bRef.BlockTableRecord, OpenMode.ForRead);
    foreach (ObjectId id in blk)
        AttributeDefinition att=tran.GetObject(id,OpenMode.ForRead) As AttributeDefinition;
        if (att!=null)
            if (att.Constant)
                if (att.Tag.ToUpper()=="MY_TARGET_ATT")
                    MessageBox.Show("The value I am looking for is " + att.TextString);
                    att.UpgradeOpen();
                    att.TextString="New Value;
    tran.Commit();
//since you changed constant attribute's value in block definition, all
//Blockreferences of this block in the drawing will also change. Do
//a Regen will show the effect
Editor.Regen();
 HTH.
0 Kudos
Post 5 of 7
03-22-2012 09:40 PM in reply to: hakand
Thank you very much for the reply. That has helped me a lot in gauging a clear understanding.
I have implemented your suggestion into my code but there is still an issue.
I keep getting this error on creating the Attributedefinition:
Unable to cast object of type
'Autodesk.AutoCAD.DatabaseServices.Polyline' to type 'Autodesk.AutoCAD.DatabaseServices.Attributedefinition'
This happens to all types of blocks, whether it be polyline, solid3d etc.
What type should the object be for it to be changed successfully?
Here is my new code below, the 'For Each id As ObjectId In btr' loop has been added in as suggested.
What am I doing wrong here?
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Try
            Dim filList As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.Start), "INSERT")}
            Dim filter As New SelectionFilter(filList)
            Dim opts As New PromptSelectionOptions()
            opts.MessageForAdding = "Select block references: "
            Dim res As PromptSelectionResult = ed.GetSelection(opts, filter)
            If res.Status <> PromptStatus.OK Then
                Return
            End If
            Dim selSet As SelectionSet = res.Valu
                Dim obj As DBObject = tr.GetObject(blkId, OpenMode.ForRead)
                    If ad IsNot Nothing Then
                        If ad.Constant = False Then
                            If ad.Tag.ToUpper = "CATEGORY" Then
                                grouparray.Add(ad.TextString)
                            End If
                        End If
                    End If
                Next
Again .. Many thanks for everyones time, it is much appreciated,
HD
217 Kudos
Post 6 of 7
03-23-2012 06:44 AM in reply to: hakand
The c# statement
To:
0 Kudos
Post 7 of 7
03-25-2012 02:38 PM in reply to: norman.yuan
Thanks Norman, that did the trick!
Much appreciated with the time spent helping me with my issue.
