VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Get the values of the parameters in a form
3 REPLIES 3
matrax1405
348 Views, 3 Replies
I want to get the values of the parameters in a form and be able to change and when it does the values are sent to an Excel spreadsheet. Just that I can not.
sent him pictures, I hope you can help me.
Tags (2)
3 REPLIES 3
norman.yuan
in reply to: matrax1405
This forum is traditionally for VBA toplc. So, if you are to do what you want with VBA, you are out of luck: there is no way for VBA to parameters/constarins introduced into AutoCAD since Acad2010.
You'll need to use ObjectARX C++ or .NET API for that.
Norman Yuan
Drive CAD With Code
matrax1405
in reply to: norman.yuan
Hi thanks for replying
Do not need to do it with VBA and have AutoCAD 2014
okay if I use ObjectARX C + + or. NET API, you will have an example that could  help me please?
norman.yuan
There is very few code samples one can find. This link would be helpful:
http://through-the-interface.typepad.com/through_the_interface/2011/08/a-simplified-net-api-for-acce...
Norman Yuan
Drive CAD With Code
”Boost
