VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Get folder name in path
3 REPLIES 3
XIJIANGWOO
934 Views, 3 Replies
Hi guys,
I am currently using this code to get the folder name (fourth) containing the current drawing.
FolderName = Dir(ThisDrawing.path, vbDirectory)
 What would I use if I wanted to get the foldername one level up (third)?
ex. C:\FIRST\SECOND\THIRD\FOURTH
Any help is greatly appreciated.
Shawn
3 REPLIES 3
use function SPLIT (>>>details<<<) with "\" as separator to get an array of directories building up the path.
Remove the last item of that array.
Use function JOIN (>>>details<<<) to create a string of this array.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
XIJIANGWOO
in reply to: XIJIANGWOO
I will explore that, I'm not fluent in coding,  Will that work if the folder one level up is not always the same?  Basically I am trying to take a folder name that is one level up from the parent folder and put it into a titleblock. The code
allows me to grab the name of the file's parent folder whatever name that may be and put it into the drawing  titleblock.
Thanks for all of the help.
bojko108
As [alfred.neswadba] said you can use Split() function to get previous folders from full path. The code is in .NET but I think in VBA is similar to this:
                      string path=@"C:\FIRST\SECOND\THIRD\FOURTH";
                      string[] wtf = path.Split('\\');
                      string first = wtf[0];                                       // first = c:
                      string second = wtf[0] + "\\" + wtf[1];            // second = "c:\\FIRST"
”Boost
