Hi guys,
I am currently using this code to get the folder name (fourth) containing the current drawing.
FolderName = Dir(ThisDrawing.path, vbDirectory)
What would I use if I wanted to get the foldername one level up (third)?
ex. C:\FIRST\SECOND\THIRD\FOURTH
Any help is greatly appreciated.
Shawn
use function SPLIT (>>>details<<<) with "\" as separator to get an array of directories building up the path.
Remove the last item of that array.
Use function JOIN (>>>details<<<) to create a string of this array.
- alfred -
I will explore that, I'm not fluent in coding, Will that work if the folder one level up is not always the same? Basically I am trying to take a folder name that is one level up from the parent folder and put it into a titleblock. The code
allows me to grab the name of the file's parent folder whatever name that may be and put it into the drawing titleblock.
Thanks for all of the help.
As [alfred.neswadba] said you can use Split() function to get previous folders from full path. The code is in .NET but I think in VBA is similar to this:
string path=@"C:\FIRST\SECOND\THIRD\FOURTH";
string[] wtf = path.Split('\\');
string first = wtf[0]; // first = c:
string second = wtf[0] + "\\" + wtf[1]; // second = "c:\\FIRST"
