VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Flatshot command (3D to 2D)
3 REPLIES 3
1829 Views, 3 Replies
it is possible for this command "Flatshot", to bypass the dialog box?  Just by using text line.
or
It is possible to use "Flatshot" command in VBA.
Thank's
Alain
3 REPLIES 3
bikelink
Up the same question. How can I invoke the command without dialog box ?
thanks in advance!
in reply to: bikelink
It is not possible not to show the dialog. Just invoke the command Flatshot, choose configuration you want, click ok and the control returns to code.
    '' FlatShot
    Call DOC1.SendCommand("flatshot" & vbCr & "0,0,0" & vbCr & "1" & vbCr & "1" & vbCr & "0" & vbCr)
bikelink
thank Youo very much, i'll try as soon as possible
”Boost
