I need to fillet two lines with a specified radius using VBA. I have not been able to find anything on this subject using VBA. Any help is greatly appreciated.
Solved by fixo. Go to Solution.
Here you go, just change fillet radius on whatever you want
Attribute VB_Name = "modFilletLines" Option Explicit Sub LineFillet() Dim setName As String Dim setObj As AcadSelectionSet setName = "$Lines$" On Error GoTo Err_Control Dim fType(0) As Integer, fData(0) Dim oSset As AcadSelectionSet fType(0) = 0: fData(0) = "LINE" Dim dxfcode As Variant Dim dxfdata As Variant dxfcode = fType: dxfdata = fData Dim setColl As AcadSelectionSets With ThisDrawing Set setColl = .SelectionSets For Each setObj In setColl If setObj.Name = setName Then .SelectionSets.Item(setName).Delete Exit For End If Next Set oSset = .SelectionSets.Add(setName) End With oSset.SelectOnScreen dxfcode, dxfdata If oSset.Count <> 2 Then MsgBox "Select 2 lines only" Exit Sub End If Dim lnf As AcadLine Dim lns As AcadLine Set lnf = oSset.Item(0) Set lns = oSset.Item(1) Dim hdlf As String: hdlf = lnf.Handle Dim hdls As String: hdls = lns.Handle Dim filrad As Double filrad = ThisDrawing.GetVariable("filletrad") ThisDrawing.SetVariable "filletrad", 25# ThisDrawing.SetVariable "cmdecho", 1 Dim cmd As String cmd = "(command " & Chr(34) & "_.fillet" & Chr(34) & " (handent " & Chr(34) & hdlf & Chr(34) & ")" & Chr(32) & "(handent " & Chr(34) & hdls & Chr(34) & ")" & Chr(32) & Chr(34) & Chr(34) & Chr(32) & Chr(34) & Chr(34) & ")" & vbCr ThisDrawing.SendCommand (cmd) Err_Control: If Err.Number <> 0 Then MsgBox Err.Description End If End Sub
