Give this a shot
~'J'~
Option Explicit
'' Requires:
'' AutoCAD/ObjectDBX Common 17.0 Type Library (for A2007)
'' Microsoft Scripting Runtime
Public Function BrowseForFolderF(ByVal msg As String) As String
Dim oBrowser, folderObj, folderAcpt As Object
Dim folderStr As String
Set oBrowser = ThisDrawing.Application.GetInterfaceObject("Shell.Application")
Set folderAcpt = oBrowser.BrowseForFolder(vbOKOnly, msg, vbDefaultButton3, 0)
With folderAcpt
Set folderObj = .Self
folderStr = folderObj.Path
End With
Set folderObj = Nothing
Set folderAcpt = Nothing
Set oBrowser = Nothing
BrowseForFolderF = folderStr
End Function
Public Function CheckFolder(ByVal strPath As String) As Variant
Dim objFolder ''As Scripting.Folder
Dim objFile ''As Scripting.File
Dim objSubdirs ''As Scripting.Folders
Dim objLoopFolder ''As Scripting.Folder
Dim varFs() As Variant
Dim m_objFSO, n, m_lngFileCount
Set m_objFSO = CreateObject("Scripting.FileSystemObject")
Set objFolder = m_objFSO.GetFolder(strPath)
' Check files in this directory
n = -1
For Each objFile In objFolder.Files
If UCase$(Right$(objFile.ShortPath, 4)) = ".DWG" Then
m_lngFileCount = m_lngFileCount + 1
n = n + 1
ReDim Preserve varFs(n)
varFs(n) = objFile.Path
Next objFile
' Loop through all subdirectories and
' do the same thing.
Set objSubdirs = objFolder.SubFolders
For Each objLoopFolder In objSubdirs
CheckFolder objLoopFolder.Path
Next objLoopFolder
Set objSubdirs = Nothing
Set objFolder = Nothing
CheckFolder = varFs
End Function
Private Sub CreateCSVFile(fso As Variant, strFname As String)
Dim tf
If Not fso.FileExists(strFname) Then
Set tf = fso.CreateTextFile(strFname, True)
Set tf = Nothing
End Sub
Private Sub WriteToCSVFile(strFname As String, strData As String)
Open strFname For Append As #1
Write #1, strData
Close #1
End Sub
Sub BatchReadSummInfo()
Dim oblkRef As AcadBlockReference
Dim objFnd As Object
Dim indx As Integer
Dim iFiles() As Variant
Dim m_objFSO
Dim fold, DwgName As String, cnt As Integer, nm As String
fold = BrowseForFolderF("Select Folder To Read SummaryInfo")
iFiles = CheckFolder(fold)
Dim fPath As String
fPath = ThisDrawing.Path & "\SummInfo.txt"
'//CreateCSVFile m_objFSO, "C:\Temp\SummInfo.txt" '// CHANGE TEXT FILE NAME HERE
CreateCSVFile m_objFSO, fPath
Dim oDbx As New AxDbDocument
Set oDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.17") '' or 16 for A2005-6
On Error Resume Next
For indx = LBound(iFiles) To UBound(iFiles)
DwgName = iFiles(indx)
oDbx.Open DwgName
WriteToCSVFile fPath, DwgName
WriteToCSVFile fPath, "_________________________________"
With oDbx
Dim Author As String
Author = .SummaryInfo.Author
WriteToCSVFile fPath, "Author: " & Author
Dim Comments As String
Comments = .SummaryInfo.Comments
WriteToCSVFile fPath, "Comments: " & Comments
Dim HLB As String
HLB = .SummaryInfo.HyperlinkBase
WriteToCSVFile fPath, "HyperlinkBase: " & HLB
Dim KW As String
KW = .SummaryInfo.Keywords
WriteToCSVFile fPath, "Keywords: " & KW
Dim LSB As String
LSB = .SummaryInfo.LastSavedBy
WriteToCSVFile fPath, "LastSavedBy: " & LSB
Dim RN As String
RN = .SummaryInfo.RevisionNumber
WriteToCSVFile fPath, "RevisionNumber: " & RN
Dim Subject As String
Subject = .SummaryInfo.Subject
WriteToCSVFile fPath, "Subject: " & Subject
Dim Title As String
Title = .SummaryInfo.Title
WriteToCSVFile fPath, "Title: " & Title
End With
Set oDbx = Nothing
Next indx
End Sub
