VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
bherber
248 Views, 1 Reply
Fatal Error
i just started transfering all my VB and VBA code from 2013 to 2015 and i can get any code to consistantly work.  i now am getting the error "Fatal Error" Unhandled access violation reading 0x000b Exception at cbce2745h"  it is the exact same modules i was using in 2013.  i also patched my CAD fully using the Application manager.  I am testing on 2 differnt systems and they both are crashing out.  Also when this is happening it is crashing out and exiting Autocad.
Tags (2)
1 REPLY 1
doglips
in reply to: bherber
Unfortunately some of the API calls and other stuff are handled differently in 2015 than they were in 2013. It's an Autodesk thing as I had the same issue going from 2013 to 2014. Same OS, same computer.
”Boost
