Hi Guys,
I need some assistance. Is their a way to know or extract the file type or file extension
of an Extrenal Reference file?
Thanks in advance....
Solved by truss_85. Go to Solution.
You can use path property to get extension. Like below...
Public Sub export_external() Dim oExternal As AcadExternalReference Dim oEnt As AcadEntity Dim pt_pnt(0 To 2) As Double ThisDrawing.Utility.GetEntity oEnt, pt_pnt, "select a referance:" Set oExternal = oEnt MsgBox oExternal.Path End Sub
Thanks Truss for quick reply...
Tried your suggestion and I got it...
One more question pls!!!!
Is their a way to extract the External Ref. File with a status of Unreferenced???
Thanks Again....
Ajustin
I am glad to help.
Sorry I could not think display status of EXTERNAL REFERENCE. I could not help that one.
Best Regards...
