Show only
Search instead for
Is there a way to explode a block, then use previous to add what was in the block to a selection set. Is there another way other then using the send commmand? Thanks for any advice.
I did some searches on the explode method and tried some of the ideas. Is there a way to get around the copied block, or is it easier to use object.delete?
my last question, when I run this simple code, I goto command line and type "move" Previous nothing is selected. I am hoping to select previous for a selection set. Is my process way off?
Sub BlockProperties()
Dim Block As AcadBlockReference
Dim ReturnObj As AcadObject
Dim pt As Variant
At risk of sounding very lost, I am trying to get items from a block "text". I read that it can be done with with Explode Method and I also see Item Method. Would some body be able to provide a simple example for me to break down myself. A simple block with a piece of text and a user form to view the text from the block.
A block w/ text, interesting.
The block (not the blockreference) has all the text in it. Cycle through the entities within the block, check for type text or mtext, then grab the .TextString property to have the text
