VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Excel VBA execute: acadApp.ActiveDocument.SendCommand "-bedit Ankers_R"
15 REPLIES 15
Message 1 of 16
3655 Views, 15 Replies
Hello!
I've got a block named: Ankers_R
I want to open this block via Excel VBA and the only thing I cant get it done is do the last execute enter to start.
if I put in the code:
He wil execute -bedit and fill in Ankers_R on the commandline so I only have to hit enter and it goes to the editor...
I just cant figur out how to adjust this code to let it do this last enter cause when you leave a space open for enter it just sees it as text...
Any ideas?
Kind regards!
15 REPLIES 15
Message 2 of 16
Alfred.NESWADBA
try that:
acadApp.ActiveDocument.SendCommand "-bedit Ankers_R" & vbCr
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 16
in reply to: Alfred.NESWADBA
Thnx! works perfectly
Message 4 of 16
ok, maybe it doesnt works that perfectly...
I got another problem now.
When the command is executed he opens the editor but somehow I cant see the dynamic features of a block inside that block...
When I manually open it I do see them....
What I'm trying to accomplish is that I can adjust the 2 dynamic grips so I can add a new length to them via excel.
(I've never learned to scripting things beside using scripts from others and adjust them, so I lack allot at knowing code language to find solutions...)
Any ideas?
Kind regards!
Message 5 of 16
Alfred.NESWADBA
May I ask you more detailed about "adjust 2 dynamic grips"?
Do you mean you want to modify the blockdefinition ... or when the block is already inserted you want to modify the parameters "SCHAAL" and "Angle1" to resize/rotate that one blockreference?
If you mean the second one then you never have to start into blockeditor (modifying a blockdefinition would replace all blockreferences already inserted with the new modification you do in the blockeditor).
To access the parameters for the blockreference (the inserted object in modelspace or paperspace) then you can't do that using SendCommand. Look e.g. >>>this thread<<< or use google to search for the words >>>AutoCAD VBA GetDynamicBlockProperties<<<, that show some blogs and threads discussing the modification of parameters within a dynamic block.
HTH, - alfred -
Alfred NESWADBA
Message 6 of 16
Thanks Alfred for that information, it will help me allot to try to adjust the dynamic grip lengths!
But I dont want to adjust Schaal and angle.
If you open the block, you can see another block with 2 dynamics inside it.
so first I want to adjust distance1 length and after that the length of distance2.
That's what I hope to find in your useful links.
But the weird thing is, when I open the blockeditor via excel it doesnt show those 2 distances...
Edit,
I just notice it doenst opens the block, it opens the block and puts in the block that needs to be opent...
gonna try some things cause this I dont get...
If you know something pls reply!
Thanks in advance!
Edit2,
I've got some mistakes in my block names what I think causes the last problems...
I'll let you know if I get it fixed 🙂
Edit3,
Its fixed....
I used an old blockname to open the block so gonna try to write the codes for the dynamics...
thnx for the help so far!
Message 7 of 16
OK, your link helped me very good cause now I managed to adjust the distances.
The thing I cant figure out here is if I put hard numbers it just works fine:
 If dybprop(i).PropertyName = "Distance1" Then
 dybprop(i).Value = 20000#
But if I put a string to it something like this:
Dim leng As Integer, length As String
 leng = Cells(1, 1).Value
 length = leng & "#"
 dybprop(i).Value = length
It doesnt understand what to do with the string, is it because a string is not a number? but I cant use an integer too because of the #... I tried this too but wont work...
dybprop(i).Value = leng & "#"
Maybe the solution is simple but I have not the experience and cant find it at google so far 🙂
Message 8 of 16
Alfred.NESWADBA
try
dybprop(i).Value = Val(length)
or
dybprop(i).Value = CDbl(length)
...as you can't store a string value (that might contain "IT IS TEN CM LONG") as double (as numeric value with decimal places).
So you have to convert the content of the string-variable to a double value.
HTH, - alfred -
Alfred NESWADBA
Message 9 of 16
Thnx Alfred!
I tried cdbl before but didnt work, but Val(length) did the trick!
Many thanks again!
Message 10 of 16
can you help me with one last thing:
I need to save the block under a new name and the new name is a string but thats not a problem I think.
I tried via commandline but that wont work because of the inputbox it opens and searching for something simular as like changing the distances but I cant find the right stuff to get it done...
Do you have another good link or maybe the code?
Message 11 of 16
Alfred.NESWADBA
What command is it that you used?
Generally: commands that raises dialogs can in most cases be started with a dash in front, so e.g.
command LAYER starts the dialog
command -LAYER starts the same command, but all is done in the command-line
For filedialogs you also can try to disable the sysvar FILEDIA, so if you try to save a drawing then you can avoid the filedialog by setting FILEDIA to 0 (and after your macro back to the value that was stored before you started your macro).
- alfred -
Alfred NESWADBA
Message 12 of 16
The command I uses is:
"naam" is a string
acadApp.ActiveDocument.SendCommand "bsaveas" & vbCr & naam & vbCr
but it wont fill in the name cause of the dialogbox.
-bsaveas is unknown by autocad unfortunately.
and filedia doesnt block the dialogbox from opening.
So i dont think I should save a new block via commandline.
But have no idea how to set up the a proper code that does like:
naam = Cells(row, 1).Value
block.saveas naam
See the attach for the full VBA.
Message 13 of 16
Alfred.NESWADBA
Yep, I see, try that instead:
ThisDrawing.SendCommand("(command ""_BSAVEAS"" " & naam & ")" / vbCr
The way here is to go through a lisp statement as within lisp also some dialogs are disabled, and here it seems to be the only option.
HTH, - alfred -
Alfred NESWADBA
Message 14 of 16
hmmm VBA cant load that line of code...
its weird that the -bsaveas doesnt excists cause the -bsave does....
Maybe you can take a look to tryout the code you think it should be...
Message 15 of 16
Alfred.NESWADBA
sorry, typos ;(
   ThisDrawing.SendCommand "(command ""_BSAVEAS""" & """" & naam & """)" & vbCr
- alfred -
Alfred NESWADBA
Message 16 of 16
It works 😄
I changed it too:
acadApp.ActiveDocument.SendCommand "(command ""_BSAVEAS""" & """" & naam & """)" & vbCr
Thnx allot for the help!
”Boost
