The EndSave event, as its name implies, fires *after* the
document has been saved, so if you want to update something
you need to use the BeginSave event.
As far as your event sourde being disconnected, that should
only occur if the variable that you've assigned the event source
object to was reassigned.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4810527@discussion.autodesk.com...
> I am trying to update title block attributes when ever a file is saved or
saved as. I have tried to use application level endsave and document level
endsave events and they both work but they only work once. Then I have to
run the initialize macro to get them to work again. I thought you only need
to initialize them only once. If this is not the case then what do I need to
do to keep the events active. I am using AutoCADE 2005
