VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Events in VB !
3 REPLIES 3
alankar
498 Views, 3 Replies
Events in VB !
Hi Friends,
I am in a problem, I want to get event notification in VB (not VBA) like we do in VBA for AutoCAD.
As I want to see which command has started and completed (like Acaddocument_Begincommand and Endcomand events. Is it possible to get event notification in VB6 without using Third party apps, or with using these ?
Thanks in advance
3 REPLIES 3
in reply to: alankar
http://discussion.autodesk.com/search.jspa?numResults=25&source=viewforum%7C33&q=vb6+events&inputEntered=true&objID=f33
wrote in message news:5322589@discussion.autodesk.com...
Hi Friends,
Thanks in advance
Dim the autocad application withevents.
You should then be able to use the application events.
You can also dim the document withevents.
Hi Friends,
Thanks in advance
alankar
Thanks Paul and Mark,
I've got, how to use Events in VB. I used BeginCommand and EndCommand events successfully.
Thanks for your help.
Alankar
”Boost
