Dear friends
New to using VBA with AutCAD. On my drawing I have to plot some line which I am able to plot
using VBA. But when it comes to delete those lines, I have to do it manually. So gave a try to BLOCKS.
When I run the macro, I get following error -
Run-time error - 2145320929(802100f)
AutoCAD is unable to service automation request.
Please help 🙂
Have a nice day
JB
dear
My Code --
Sub PlotArcs()
Dim lineLen As Double
Dim cent1(0 To 2) As Double
Dim cent2(0 To 2) As Double
Dim r1(0 To 2) As Double
Dim r2(0 To 2) As Double
Dim stPt(0 To 2) As Double
Dim enPt(0 To 2) As Double
Dim intPt As Variant
Dim intPt1(0 To 2) As Double
Dim intPt2(0 To 2) As Double
Dim v As Variant
Dim circle1 As AcadCircle
Dim circle2 As AcadCircle
Dim radLen As Double
Dim nLine As AcadLine
Dim cirCol As AcadAcCmColor
Dim verCol As AcadAcCmColor
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#
insertionPnt(1) = 0#
insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "PlotARCBlock")
Set verCol = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16")
Call verCol.SetRGB(255, 10, 255)
Set cirCol = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16")
Call cirCol.SetRGB(91, 91, 91)
'************ ERROR COMING HERE WHEN DEBUGGED *******************************
v = ThisDrawing.Utility.GetPoint(, "First Circle Center Point... ")
cent1(0) = v(0)
cent1(1) = v(1)
cent1(2) = v(2)
v = ThisDrawing.Utility.GetPoint(, "Select the Radius Point for First Circle... ")
r1(0) = v(0)
r1(1) = v(1)
r1(2) = v(2)
Set nLine = blockObj.AddLine(cent1, r1)
radLen = nLine.Length
Set circle1 = blockObj.AddCircle(cent1, radLen)
'Set circle1 = ModelSpace.AddCircle(cent1, radLen)
circle1.TrueColor = cirCol
Set circle2 = blockObj.AddCircle(r1, radLen)
'Set circle2 = ModelSpace.AddCircle(r1, radLen)
circle2.TrueColor = cirCol
intPt = circle1.IntersectWith(circle2, acExtendNone)
' Print all the intersection points
Dim I As Integer, j As Integer, k As Integer
If VarType(intPt) <> vbEmpty Then
For I = LBound(intPt) To UBound(intPt)
If k = 0 Then
intPt1(0) = intPt(j)
intPt1(1) = intPt(j + 1)
intPt1(2) = intPt(j + 2)
'MsgBox "First Point - " & intPt1(0) & ", " & intPt1(1)
ElseIf k = 1 Then
intPt2(0) = intPt(j)
intPt2(1) = intPt(j + 1)
intPt2(2) = intPt(j + 2)
'MsgBox "Second Point - " & intPt2(0) & ", " & intPt2(1)
I = I + 2
j = j + 3
k = k + 1
Next
Set nLine = blockObj.AddLine(intPt2, intPt1)
'Set nLine = ModelSpace.AddLine(intPt2, intPt1)
lineLen = nLine.Length
nLine.TrueColor = cirCol
Dim ang As Double
ang = ThisDrawing.Utility.AngleFromXAxis(intPt1, intPt2)
'Now plotting the Outer Arc
Dim arcObj As AcadArc
Dim startAngleInRadian As Double
Dim endAngleInRadian As Double
startAngleInRadian = 270 * 3.141592 / 180#
endAngleInRadian = 90 * 3.141592 / 180#
Set arcObj = blockObj.AddArc(cent1, lineLen, startAngleInRadian, endAngleInRadian)
'Set arcObj = ModelSpace.AddArc(cent1, lineLen, startAngleInRadian, endAngleInRadian)
arcObj.TrueColor = verCol
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 5000#: insertionPnt(1) = 5000#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "PlotARCBlock", 1#, 1#, 1#, 0)
End Sub
Please help 🙂
Have a nice day
What is the version of autocad you are using? I think that this error means that other process is running and the AutoCAD wait's for you to enter a command (instead you call GetPoint method). Look where you call that procedure (PlotArcs()) and make shure that the other process are closed. I'm using AutoCAD 2006 and the code you give runs without errors, so check how you call the procedure PlotArcs().
EDIT: If you are using UserForm try to hide it before calling GetPoint method.
Me too using 2006..!!
But getting the same error....
Have a nice day
JBest
try to use this :
Set CCouleur = New AcadAcCmColor
Call CCouleur.SetRGB(CR, CV, CB)
Layer.TrueColor = CCouleur
Set CCouleur = Nothing
it is you getapplication ... causing the error with my acad R2004.
change CCouleur with your name in your prog.
Sr. i don't have time for check your code.
dear friends,
its working now....
just replaced 5000 with 0. 🙂
But now when I run it number of times, all the earlier plots are
also visible. It means that the block is storing them.
How to clear that block so that everytime I plot. I get a fresh
plot, instead of all the previous plots?
have a nice day
Jbest
