Visual Basic Customization
New Member
yvesallaire2562
Message 1 of 4 (253 Views)
Error opening files..
253 Views, 3 Replies
03-06-2012 01:35 PM
This is usually an easy task, but now I'm not able to see what could be wrong!!!
Here is the simple code:
Dim fileName As String, path As String, ObjDWG As AcadDocument
    path = "C:\Temp\geotic\Tiri\"
    fileName = Dir(path & "*.dwg")
    ThisDrawing.Application.Documents.Open (path & fileName)
I see that Autocad (2011) is trying to open the file up to some point, then Error -2145386153 (80200157)
I can open the file manually without any problem, note that the file I'm trying to read is from a third party software
If I save the file with autocad and try to open it with VBA... still crash.
No problem with a native drawing
A sample is attached.
Hallex
Message 2 of 4 (245 Views)
Re: Error opening files..
03-06-2012 10:25 PM in reply to: yvesallaire2562
Check this before:
MsgBox Dir(path & "*.dwg")
New Member
yvesallaire2562
Message 3 of 4 (243 Views)
03-07-2012 05:20 AM in reply to: Hallex
I solved the problem, I have FME a software I use to translate files, (same software used by inside autocad) and it to saved all my files to DXF.
But I ran into another problem, with an another method.
.saveas...
        fileName = fileName & ".dwg"
        'fileName = path & "3D\" & fileName
         ThisDrawing.SaveAs fileName, ac2007_dwg
If I try to do the saveas to a different folder it crashes... simply saveas to the default folder it works!!!???
this is why I've put a remark in front of the second line above!
Thanks.
Hallex
Message 4 of 4 (212 Views)
03-19-2012 01:53 AM in reply to: yvesallaire2562
Try to use:
fileName = path & "\3D\" & fileName
Not sure about thogh just a shot in the dark
~'J'~
