Hi everybody,
I upgraded many VBA routine to AutoCAD 2014. Each time I run a macro, when I quit AutoCAD, I have error message. Sometimes it ask me to send an error report, sometimes I see a quick popup error message and a beep. If I don't run any macro no errors occurs. The macros work well, it is only when I exit AutoCAD.
Any idea?
André
Which error?
Have you seen >>>that thread<<<? Is it the same error you get?
- alfred -
Hi Alfred,
It is exactly the same message as mentionned on the thread you reference. This error cause no problem, it's just annoying. Do you find any solutions about that?
In the last few years, my custom development was made with VB .Net not VBA. Now I prefered .Net but sometimes for maintenance purpose I need VBA. I would think that the new VBA 7.1 solve all the problems but maybe not.
André
Sorry, no, I have not found any way to avoid it, otherwise I would have written it in the other post.
And as you mentioned it does not do anything bad to data, so I have not spent much time into it.
- alfred -
