not sure what you're after. If you could post some example it would help
maybe SelectByPoligon method of the SelectionSet object could be of any help
its online AutoCAD Active X and VBA Reference, says the following
SelectByPolygon Method
Selects objects within a fence and adds them to the selection set.
Signature
object.SelectByPolygon Mode, PointsList, FilterType, FilterData
Object
SelectionSet
The object this method applies to.
Mode
AcSelect enum; input-only
acSelectionSetFence
acSelectionSetWindowPolygon
acSelectionSetCrossingPolygon
PointsList
Variant (array of doubles); input-only
An array of 3D WCS coordinates specifying the selection fence.
FilterType
Integer; input-only; optional
A DXF group code specifying the type of filter to use.
FilterData
Variant; input-only; optional
The value to filter on.
Remarks
The following selection modes are available:
Fence
Selects all objects crossing a selection fence. The fence is defined by coordinates in Point1.
WindowPolygon
Selects objects within a polygon defined by Point1.
CrossingPolygon
Selects objects within and crossing an area defined by a polygon. Use Point1 to define the coordinates of the polygon. AutoCAD will close the last vector of the polygon. A polygon definition cannot cross itself.
This method supports the filtering mechanism.
and comes with the following example, too
Sub Example_Select() ' This example adds members to a selection set, first by crossing and ' then by filtering for circles. ' Create the selection set Dim ssetObj As AcadSelectionSet Set ssetObj = ThisDrawing.SelectionSets.Add("SSET") ' Add all object to the selection set that lie within a crossing of (28,17,0) and ' (-3.3, -3.6,0) Dim mode As Integer Dim corner1(0 To 2) As Double Dim corner2(0 To 2) As Double mode = acSelectionSetCrossing corner1(0) = 28: corner1(1) = 17: corner1(2) = 0 corner2(0) = -3.3: corner2(1) = -3.6: corner2(2) = 0 ssetObj.Select mode, corner1, corner2 ' Add all the Circles to the selection set that lie within the crossing of (28,17,0) and ' (-3.3, -3.6,0) by filtering from the current drawing Dim gpCode(0) As Integer Dim dataValue(0) As Variant gpCode(0) = 0 dataValue(0) = "Circle" Dim groupCode As Variant, dataCode As Variant groupCode = gpCode dataCode = dataValue ssetObj.Select mode, corner1, corner2, groupCode, dataCode End Sub
Thanks for your answer.
To elaborate my request, I don't need any actual selection mechanism, I'm just looking to display the selection polygon.
Example : If you run the built in "area" command, it lets you pick up some points to define the shape of which you want to measure the area. When picking points, it displays the polgon defined by those points which looks like a selection polygon but doesn't actually selects anything.
Regards.
With VBA, you are basically out of luck.
You can do it fairly easy with .NET API (or ObjectARX C++, of course).
In case you do know a bit .NET API, here is an example
http://drive-cad-with-code.blogspot.ca/2011/01/mimicking-autocads-area-command-with_20.html
However, if you really need to mimic the action with VBA, you might try to actually draw/erase/redraw lines connecting the points with each point user picks. At the end, simple erase all the lines. It is not elegent, but you can try.
Again, for this kind of tempotatry graphics, using ObjectARX/.NET API is the solution to go. Better moving to .NET API than being stuck in VBA.
Norman's piece of advice and links are very fine
in VBA the quickiest (and roughest, indeed) way would be add a Form with a button whose click event could be
Private Sub CbSelectionLikePolygon_Click() Dim returnPnt As Variant, returnPnt2 As Variant Dim iPoints As Integer Dim Points() As Double Dim AcadPoly As AcadLWPolyline Me.Hide On Error Resume Next returnPnt = ThisDrawing.Utility.GetPoint(, "select first point: ") iPoints = 1 If Not (IsNull(returnPnt)) Then ReDim Points(0 To 2 * iPoints - 1) Points(0) = returnPnt(0): Points(1) = returnPnt(1) Do returnPnt2 = ThisDrawing.Utility.GetPoint(returnPnt, "Next Point (<Esc> to Finish): ") If Err Then returnPnt2 = Null Else Call AddPoint(returnPnt2, Points, iPoints, AcadPoly) returnPnt = returnPnt2 End If Loop While Not IsNull(returnPnt2) End If On Error GoTo 0 Me.Show End Sub
where the button is supposed to be called "CbSelectionLikePolygon"
Tha "AddPoint" sub should take care of updating Points() array, delete previous LWPoly and redraw the new one
like follows
Sub AddPoint(Pnt As Variant, Points() As Double, iPoints As Integer, AcadPoly As AcadLWPolyline) If iPoints > 1 Then AcadPoly.Delete iPoints = iPoints + 1 ReDim Preserve Points(0 To 2 * iPoints - 1) Points(2 * iPoints - 2) = Pnt(0): Points(2 * iPoints - 1) = Pnt(1) Set AcadPoly = ThisDrawing.ModelSpace.AddLightWeightPolyline(Points) AcadPoly.Closed = True End Sub
to get nearer to Norman's .NET code functioning it is also possible to add a hatch to theLWPoly
but still you'd be missing the constant updating of LWPoly and hatch while moving around the mouse for the next input point
I guess it could be achieved if it would be possible to catch mouse movements via some Autocad events handler and consequently update LWPoly and its hatch. but this is something I never struggled with. And not sure about its performances however...
