Visual Basic Customization
0 Kudos
Post 1 of 7
drawing a perpendicular from a point to line
809 Views, 6 Replies
05-17-2009 10:01 AM
I have a line which is at (0,0) and (2,2). I need to draw a perpendicular to this line from point(1,0). Could someone help me with the VBA code for this?
Thanks in advance
Vinayan
Hi Vinayan,
Here is a general solution to your query. All it requires is that the
initial line has already been drawn.
You could adjust this code to solve your initial problem, just by making
the ends of the new line to be 1,0 and .5,.5
Sub Test()
On Error GoTo ErrorHandler
Dim p1(0 To 2) As Double
Dim p2(0 To 2) As Double
Dim oLine As AcadLine
Dim oLine2 As AcadLine
Dim dAngle As Double
Dim oEnt As AcadEntity
Const HalfPi = 1.5707963267949
ThisDrawing.Utility.GetEntity oEnt, p1
If TypeOf oEnt Is AcadLine Then
Set oLine = oEnt
dAngle = oLine.Angle + HalfPi
v = ThisDrawing.Utility.GetPoint(, "Select the start point")
p1(0) = v(0)
p1(1) = v(1)
v = ThisDrawing.Utility.PolarPoint(p1, dAngle, 10)
p2(0) = v(0)
p2(1) = v(1)
Set oLine2 = ThisDrawing.ModelSpace.AddLine(p1, p2)
v = oLine.IntersectWith(oLine2, acExtendBoth) ' Note the options here
p2(0) = v(0)
p2(1) = v(1)
oLine2.EndPoint = p2
oLine2.Update
Else
End If
Exit Sub
ErrorHandler:
MsgBox "Unable to complete Sub 'Test' due to" & vbCrLf & Err.Description
Err.Clear
End Sub ' Test
Laurie Comerford
VBAChallenger wrote:
> Hello, I have a line which is at (0,0) and (2,2). I need to draw a
> the VBA code for this? Thanks in advance Vinayan
Distinguished Contributor
0 Kudos
Post 2 of 7
Re: drawing a perpendicular from a point to line
05-18-2009 08:53 AM in reply to: vinayan
Dim p1(0 To 2) As Double: p1(0) = 1#: p1(1) = 0#
Dim p2(0 To 2) As Double: p2(0) = 2#: p2(1) = -1#
ThisDrawing.ModelSpace.AddLine p1, p2
05-18-2009 03:27 PM in reply to: vinayan
Hi Vinayan,
Sub Test()
Set oLine = oEnt
p1(0) = v(0)
p1(1) = v(1)
p2(0) = v(0)
p2(1) = v(1)
p2(0) = v(0)
p2(1) = v(1)
oLine2.Update
Else
End If
Exit Sub
ErrorHandler:
Err.Clear
End Sub ' Test
Laurie Comerford
0 Kudos
Post 4 of 7
05-28-2009 11:11 PM in reply to: vinayan
Hi Laurie,
I am excited to get a reply from you. Your answers have always been straight to the point..I was really wondering how to get this polarpoint thing to work in my code but was not sure..this solves my problem..
Thank you
Vinayan
0 Kudos
Post 5 of 7
05-28-2009 11:13 PM in reply to: vinayan
Hi fantum,
Thanks for the reply..but i was looking for another logic
thank you
Vinayan
0 Kudos
Post 6 of 7
05-29-2009 06:02 AM in reply to: vinayan
I had gathered as much which was why I gave you exactly what you asked for rather than doing your homework for you.
Member
0 Kudos
Post 7 of 7
05-25-2013 11:02 PM in reply to: vinayan
draw again the line, then move it to the point, rotate to 90 degree, find the intersection, trim it
