VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
drawing a perpendicular from a point to line
6 REPLIES 6
vinayan
2402 Views, 6 Replies
I have a line which is at (0,0) and (2,2). I need to draw a perpendicular to this line from point(1,0). Could someone help me with the VBA code for this?
Thanks in advance
Vinayan
6 REPLIES 6
in reply to: vinayan
Dim p1(0 To 2) As Double: p1(0) = 1#: p1(1) = 0#
Dim p2(0 To 2) As Double: p2(0) = 2#: p2(1) = -1#
ThisDrawing.ModelSpace.AddLine p1, p2
Hi Vinayan,
Here is a general solution to your query. All it requires is that the
initial line has already been drawn.
You could adjust this code to solve your initial problem, just by making
the ends of the new line to be 1,0 and .5,.5
Sub Test()
On Error GoTo ErrorHandler
Dim oLine As AcadLine
Dim oLine2 As AcadLine
Dim dAngle As Double
Dim oEnt As AcadEntity
Const HalfPi = 1.5707963267949
ThisDrawing.Utility.GetEntity oEnt, p1
If TypeOf oEnt Is AcadLine Then
Set oLine = oEnt
dAngle = oLine.Angle + HalfPi
v = ThisDrawing.Utility.GetPoint(, "Select the start point")
p1(0) = v(0)
p1(1) = v(1)
v = ThisDrawing.Utility.PolarPoint(p1, dAngle, 10)
p2(0) = v(0)
p2(1) = v(1)
Set oLine2 = ThisDrawing.ModelSpace.AddLine(p1, p2)
v = oLine.IntersectWith(oLine2, acExtendBoth) ' Note the options here
p2(0) = v(0)
p2(1) = v(1)
oLine2.EndPoint = p2
oLine2.Update
Else
End If
Exit Sub
ErrorHandler:
MsgBox "Unable to complete Sub 'Test' due to" & vbCrLf & Err.Description
Err.Clear
End Sub ' Test
Laurie Comerford
VBAChallenger wrote:
> Hello, I have a line which is at (0,0) and (2,2). I need to draw a
> the VBA code for this? Thanks in advance Vinayan
vinayan
Hi Laurie,
I am excited to get a reply from you. Your answers have always been straight to the point..I was really wondering how to get this polarpoint thing to work in my code but was not sure..this solves my problem..
Thank you
Vinayan
vinayan
Hi fantum,
Thanks for the reply..but i was looking for another logic
thank you
Vinayan
I had gathered as much which was why I gave you exactly what you asked for rather than doing your homework for you.
MakCADD
draw again the line, then move it to the point, rotate to 90 degree, find the intersection, trim it
”Boost
