VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
draw line perpendicular to line
6 REPLIES 6
1149 Views, 6 Replies
Hi all,
                I like to draw line perpendicular to line using vba. Anyone have sample code?
Ramanusu
6 REPLIES 6
Hallex
Try this code
Option Explicit
'' based on code written by Tony Tanzillo
'' request check "Break on Unhandled Errors" in  General options
Public Sub LoopExample()
Dim ptColl As Collection
Set ptColl = New Collection
Dim intOsm As Integer
intOsm = ThisDrawing.GetVariable("OSMODE")
ThisDrawing.SetVariable "OSMODE", 35
Dim Msg As String
Msg = vbCrLf & "First point: "
Dim MyPoint As Variant
Do
On Error Resume Next
MyPoint = ThisDrawing.Utility.GetPoint(, Msg)
If Err Then
Err.Clear
Exit Do
On Error GoTo 0
ptColl.Add MyPoint
Msg = vbCrLf & "Next point [ or ENTER to exit ]: "
Loop
On Error GoTo 0
Dim oEntity As AcadEntity
Dim varPt As Variant
ThisDrawing.Utility.GetEntity oEntity, varPt, vbCr & "Select a projection oLine >> "
If Not oEntity Is Nothing Then
If TypeOf oEntity Is AcadLine Then
Dim oLine As AcadLine
Set oLine = oEntity
Dim stPt As Variant, endPt As Variant
stPt = oLine.StartPoint: endPt = oLine.EndPoint
Dim Pi As Double
Pi = Atn(1#) * 4
Dim ang As Double
ang = ThisDrawing.Utility.AngleFromXAxis(stPt, endPt)
Dim outColl As Collection
Set outColl = New Collection
Dim itm As Variant
Dim num As Integer
For num = 1 To ptColl.Count
itm = ptColl.Item(num)
Dim tmpPt1(2) As Double
tmpPt1(0) = itm(0): tmpPt1(1) = itm(1): tmpPt1(2) = itm(2):
Dim tmp As Variant
tmp = ThisDrawing.Utility.PolarPoint(tmpPt1, ang - Pi / 2, 1)
Dim tmpPt2(2) As Double
tmpPt2(0) = tmp(0): tmpPt2(1) = tmp(1): tmpPt2(2) = tmp(2):
Dim oXLine As AcadXline
Set oXLine = ThisDrawing.ModelSpace.AddXline(tmpPt1, tmpPt2)
Dim intPt As Variant
intPt = oXLine.IntersectWith(oLine, acExtendNone)
outColl.Add intPt
oXLine.Delete
Next num
Dim i As Integer
Dim j As Integer
Dim dblDist As Double
For i = 1 To outColl.Count
Set oLine = ThisDrawing.ModelSpace.AddLine(outColl.Item(i), ptColl.Item(i))
Next i
ThisDrawing.SetVariable "OSMODE", intOsm
Set outColl = Nothing
Set ptColl = Nothing
End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
RICVBA
thank you Hallex for the code you posted
and, since I can't help doing it, here's my optimization or, better, what I think it is
Option Explicit
''' revised by RICVBA 22_02_2014
Public Sub LoopExample() Dim ptColl As Collection, outColl As Collection Dim intOsm As Integer, i As Integer Dim Msg As String Dim oEntity As AcadEntity Dim varPt As Variant, Pt1 As Variant, Pt2 As Variant Dim oLine As AcadLine, oXLine As AcadXline Dim Pi As Double, ang As Double intOsm = ThisDrawing.GetVariable("OSMODE") ThisDrawing.SetVariable "OSMODE", 35 Set ptColl = New Collection Msg = vbCrLf & "First point: " Do On Error Resume Next varPt = ThisDrawing.Utility.GetPoint(, Msg) If Err Then Err.Clear Exit Do End If On Error GoTo 0 ptColl.Add varPt Msg = vbCrLf & "Next point [ or ENTER to exit ]: " Loop On Error GoTo 0 ThisDrawing.Utility.GetEntity oEntity, varPt, vbCr & "Select a projection line >> " If Not oEntity Is Nothing Then If TypeOf oEntity Is AcadLine Then Set oLine = oEntity Pt1 = oLine.StartPoint: Pt2 = oLine.EndPoint Pi = Atn(1#) * 4 ang = ThisDrawing.Utility.AngleFromXAxis(Pt1, Pt2) Set outColl = New Collection For i = 1 To ptColl.Count Pt1 = ptColl.Item(i) Pt2 = ThisDrawing.Utility.PolarPoint(Pt1, ang - Pi / 2, 1) Set oXLine = ThisDrawing.ModelSpace.AddXline(Pt1, Pt2) outColl.Add oXLine.IntersectWith(oLine, acExtendNone) oXLine.Delete Next i For i = 1 To outColl.Count Set oLine = ThisDrawing.ModelSpace.AddLine(outColl.Item(i), ptColl.Item(i)) Next i Set outColl = Nothing End If End If ThisDrawing.SetVariable "OSMODE", intOsm Set ptColl = Nothing End Sub
I minimized variables number and made the code core run only If Not oEntity Is Nothing and TypeOf oEntity Is AcadLine
nothing you couldn't live without.
bye
RICVBA
a furtherly shorter (and presumibly faster) version
''' revised by RICVBA 23_02_2014
Option Explicit
Dim Msg As String
Dim Pt1 As Variant, Pt2 As Variant
Dim RefLine As AcadLine, oLine As AcadLine, oXLine As AcadXline
ThisDrawing.Utility.GetEntity oEntity, Pt1, vbCr & "Select a projection line >> "
        Set RefLine = oEntity
        Pt1 = RefLine.StartPoint: Pt2 = RefLine.EndPoint
        Pi = Atn(1#) * 4
        Do
            Pt1 = ThisDrawing.Utility.GetPoint(, Msg)
            If Err Then
                Err.Clear
                Exit Do
            On Error GoTo 0
            Set oXLine = ThisDrawing.ModelSpace.AddXline(Pt1, ThisDrawing.Utility.PolarPoint(Pt1, ang - Pi / 2, 1))
            Set oLine = ThisDrawing.ModelSpace.AddLine(Pt1, oXLine.IntersectWith(RefLine, acExtendNone))
            oXLine.Delete
        Loop
        On Error GoTo 0
End Sub
 just for "research" purposes
in reply to: RICVBA
Thanks a lot Hallex  & Ricvba’s . quick replay. I will check and let you know, if I have any queries.
Bye
Ramanusu
Hallex
in reply to: RICVBA
Nice changes, thanks 🙂
in reply to: Hallex
It's working perfect. i tolk both codes. I have one more query posted. If you have time. Please have look. Thank you very much.
”Boost
