VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Download the 2014 Microsoft Visual Basic for Applications Module
5 REPLIES 5
dsnodgrass
16000 Views, 5 Replies
When I try to download the enabler for the ACAD 2014 VBA enabler, there appears to be a dead link:
AutoCAD 2014 VBA module 64-bit (exe - 108797Kb)
Download the Microsoft Visual Basic for Applications Module
"Not Found
The requested URL "/sites/default/files/file_downloads/AutoCAD_2014_VBA_Enabler_r2_English_Win_64bit_dlm.sfx_.exe" was not found on this server."
Does anyone know if Autodesk has decided to discontinue support for VBA on AutoCAD 2014 along with older versions?
http://usa.autodesk.com/adsk/servlet/index?id=770215&siteID=123112#section3
5 REPLIES 5
philip.s
in reply to: dsnodgrass
Apologies for the inconvenience @dsnodgrass. This one was actually a broken link on our end, not being discontinued, which has just been updated.
Check out the following Download the Microsoft Visual Basic for Applications Module solution for access.
Here to help if additional assitance is needed, otherwise please accept as a solution so that others can benefit from this information!
dsnodgrass
in reply to: philip.s
Thank you PhilipThe link is working now.
DSnodgrass
philip.s
You're welcome!
tuli1954
any chance to get the 32GB version for windows XP?
Ed.Jobe
in reply to: tuli1954
Autodesk does not support versions older than the last 4 versions. You would have to do an internet search to see if someone has stored the file.
Ed
How to post your code.
”Boost
