While dividing a line or arc is fairly trivial and can be done
in VBA, dividing any object that the DIVIDE command works with
would not be easy to do.
However, you can use the Divide(); DivideEx(); Measure() and
MeasureEx() methods of the AcadXCurve class, which is part of
the AcadX ActiveX Extension Library, to divide/measure anything
the DIVIDE or MEASURE commands accept.
http://www.caddzone.com/acadx
"BILL_S" wrote in message news:2ED52C28C344A0C8EDBA9B12D20B4AA7@in.WebX.maYIadrTaRb...
> Is there a way to divide polylines,splines,ect using VBA and get the
> coordinates in order to use them in a routine for calculations or to export
> to another application?
