VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
display layer description
6 REPLIES 6
321 Views, 6 Replies
I am trying to get the layer description in AutoCAD 2004 and I am having no
luck. Can someone help??
Here is what I have:
Dim ObjAcad As AcadApplication, oLayer As AcadLayer
Private Sub Command1_Click()
Set ObjAcad = GetObject(, "AutoCAD.Application")
For Each oLayer In ObjAcad.ActiveDocument.Layers
MsgBox oLayer.Name ' gets layer name
MsgBox oLayer."what do I put here" ' gets layer description
Next
End Sub
6 REPLIES 6
What layer description?
R. Robert Bell, MCSE
www.AcadX.com
"Nate Hunter" wrote in message
news:096CF8A19B7BFDD000066011D81B0ED1@in.WebX.maYIadrTaRb...
no
| Next
| End Sub
In the ADT04 Layer manager there is a description field. I need to be able
to change the value in this field.
no luck. Can someone help??
Next
End Sub
"R. Robert Bell" wrote in message
news:1B92DB35E6EAB557F5CE25F424502F33@in.WebX.maYIadrTaRb...
> www.AcadX.com
> no
> | Next
> | End Sub
Basic AutoCAD has no layer descriptions. If this is in regards to an ADT
file opened in plain AutoCAD, you probably need to add a reference to
one of the ADT libraries. If this is intended to work with non-ADT
stations, you probably need to export the descriptions to an external
file and read that file in AutoCAD.
___________________________
Mike Tuersley
AutoCAD Clinic
Rand IMAGINiT Technologies
Sorry, no ADT here to help you with. Maybe on of the ADT guys here will jump
in.
www.AcadX.com
news:674F9FE6D89616411058150B61DDA63A@in.WebX.maYIadrTaRb...
able
| Next
| End Sub
| > www.AcadX.com
having
| > no
| > | Next
| > | End Sub
Nate -
There is a specific group for ADT Customization. Might want to
try there.
ADT Customization
http://discussion.autodesk.com/WebX?14@@.ee77eaa
news://discussion.autodesk.com/autodesk.aec.arch-desktop.customization
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
> to change the value in this field. (snip)
thanks I will try there
"Anne Brown" wrote in message
news:3F96BA67.A5E5C1EC@autodesk.com...
> Nate -
> try there.
> ADT Customization
> Anne Brown
> Manager, Moderator
able
”Boost
