VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Dimension a line and add text above it
11 REPLIES 11
Message 1 of 12
Pretty
330 Views, 11 Replies
Can someone please tell me why the following lines in my code are not working? I am simply trying to dimension a line and write text above it.
Sub DimensionLine(obj As AcadObject, distFromObj As Double, dimText As String)
ThisDrawing.SetVariable "DIMTAD", 1 'Not Working
ThisDrawing.SetVariable "DIMJUST", 0 'Not Working
ThisDrawing.SetVariable "DIMGAP", 0.08 'Not Working
If obj.ObjectName = "AcDbLine" Then
Dim dimObj As AcadDimAligned
Dim dimPnt1 As Variant
Dim dimPnt2 As Variant
Dim location(0 To 2) As Double
dimPnt1 = obj.StartPoint
dimPnt2 = obj.EndPoint
location(0) = dimPnt1(0) + distFromObj
location(1) = dimPnt1(1) + distFromObj
Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(dimPnt1, dimPnt2, location)
dimObj.TextInsideAlign = False
dimObj.Color = 252
dimObj.TextColor = acYellow
dimObj.AltSuppressTrailingZeros = True 'Not Working
dimObj.Update
Dim mTextObj As AcadMText
Dim width As Double
Dim txtInsPnt(0 To 2) As Double
txtInsPnt(0) = (dimObj.ExtLine1Point(0) + dimObj.ExtLine2Point(0)) / 2
txtInsPnt(1) = (dimObj.ExtLine1Point(1) + dimObj.ExtLine2Point(1)) / 2
txtInsPnt(2) = 0
width = 1
' Creates the mtext Object
Set mTextObj = ThisDrawing.ModelSpace.AddMText(txtInsPnt, width, dimText)
mTextObj.AttachmentPoint = acAttachmentPointTopCenter 'Not Working
mTextObj.Color = acYellow
ZoomAll
Else
MsgBox " Wrong object passed to DimensionLine. Object passed is " & obj.ObjectName
End If
End Sub
11 REPLIES 11
Message 2 of 12
in reply to: Pretty
Hi, Pretty
Try to suppress all lines, i.e. Extension lines, dimension lines etc
and you will be get a pure dimension text without any
~'J'~
Message 3 of 12
in reply to: Pretty
Pretty, I mean this one:
dimObj.ExtLine1Suppress = True
dimObj.ExtLine2Suppress = True
dimObj.DimLine1Suppress = True
dimObj.DimLine2Suppress = True
dimObj.Arrowhead1Type = acArrowNone
dimObj.Arrowhead2Type = acArrowNone
dimObj.TextGap = 0.08
dimObj.Update
Hth
~'J'~
Message 4 of 12
Pretty
in reply to: Pretty
Hi Fatty,
First let me thank you for your reply.
See I want the dimension lines and extension lines. But I want Mtext to be displayed above the dimension text and the direction of the text should be along the dimension line. Right now whatever I do , the direction of the Mtext is horizontal, even if the line drawn is vertical.
So I did
mTextObj.AttachmentPoint = acAttachmentPointBottomCenter
But still nothing happens.
Also even if I change the values of the System Variables, nothing just happens. Can you tell me whats going wrong?
Pretty
Message 5 of 12
in reply to: Pretty
wrote in message news:5398692@discussion.autodesk.com...
Hi Fatty,
So I did
Pretty
are you setting mTextObj.Rotation?
Message 6 of 12
in reply to: Pretty
Pretty,
I think there is no need to add mtext
Use TextPrefix property for dimension object instead
Try this one:
dimObj.TextPrefix = "Text Line1\PText Line2\PText Line3\P" ' use \P to jump next line
dimObj.Update
Hth
~'J'~
Message 7 of 12
Pretty
in reply to: Pretty
Hi MP,
I do not know the inclination of the line that I will dimension. So if I rotate Mtext so that Mtext is aligned properly for horizontal line, it is aligned wrongly for vertical line.
Also see
should align in a one way, i.e Mtext box should be placed above the line.
If I run my code with
I should see Mtext box placed differently
But that is not happening.
Same with DIMJUST, and DIMTAD setting, it to 1 or 0 is not making any difference to the drawing.
So certain lines of code just dont seem to work while others are working perfectly.
Can you tell me what the problem could be.
Is it that system variables have to declared somewhere else (in the This Drawing or something and not in sub)?
Thanks for your help,
Pretty
Message 8 of 12
Pretty
in reply to: Pretty
Hi Fatty,
This is a very different idea. I will try this and get back to you.
In the meanwhile looking at the code, can you tell me why my system variables are not working. I.e even if I change their values, nothing is reflected in the drawing.
Pretty
Message 9 of 12
Pretty
in reply to: Pretty
Hi MP:
Just doing mTextObj.Rotation = obj.angle solves the problem. So thanks for the solution. Now that my mtext is aigned with the dimension line, any suggestion on how to get it above the dimesion line?
Pretty
Message 10 of 12
Pretty
in reply to: Pretty
Thanks again,
Pretty
Message 11 of 12
in reply to: Pretty
wrote in message news:5400651@discussion.autodesk.com...
Thanks again,
Pretty
For Mtext, the location is determined by the combination of InsertionPoint
and AttachmentPoint
Read the help files on how they affect each other
Are you aware of the sub menu on the "Help" | "Additional Resources" |
"Developer Help" ?
Alt + H + R + P
this is different area of help system than F1, and has all the information
you need for this kind of task.
Hth
Mark
Message 12 of 12
Pretty
in reply to: Pretty
Hi Mark,
No I was not aware of that. Thanks for letting me know as F1 help is not always helpful.
Pretty
”Boost
