Visual Basic Customization
CodeBug
Message 1 of 3 (251 Views)
Detecting point whether it is inside or outside a closed object
251 Views, 2 Replies
10-04-2012 09:19 PM
Hi all,
I have a closed object and a line outside this object. I want to take anypoint on this polyline as a reference and check whether  that point is lying inside the closed object or outside.
Can anyone help with the logic for this or some VB code will be much appreciated.
Thanks!
or check all >>>that ones<<< waiting for you :smileywink:
- alfred -
truss_85
Message 2 of 3 (240 Views)
Re: Detecting point whether it is inside or outside a closed object
10-05-2012 01:48 AM in reply to: CodeBug
Take look that algorithm
inside poly
An other solution may be found via selection sets. you can filter points an polygonal selection set then check wanted points id.
Alfred.NESWADBA
Message 3 of 3 (236 Views)
10-05-2012 02:14 AM in reply to: CodeBug
- alfred -
Alfred NESWADBA
