VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Detecting point whether it is inside or outside a closed object
2 REPLIES 2
CodeBug
574 Views, 2 Replies
Hi all,
I have a closed object and a line outside this object. I want to take anypoint on this polyline as a reference and check whether  that point is lying inside the closed object or outside.
Can anyone help with the logic for this or some VB code will be much appreciated.
Thanks!
2 REPLIES 2
truss_85
in reply to: CodeBug
Take look that algorithm
inside poly
An other solution may be found via selection sets. you can filter points an polygonal selection set then check wanted points id.
Alfred.NESWADBA
or check all >>>that ones<<< waiting for you 😉
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
