Im connecting to an SQL Express server which is remote.
I currently am using the windows Data sources (ODBC) utility to establish the connection however it is a bit slow.
I'm wondering if I were to use the built-in feature dbconnect if the transactions would be quicker. Here is the problem:
I open dbconnect and create a connection to the database with no problem. I can look at the tables etc from within the dbconnect utility.
I'm trying to use this connection to run queries from within a VBA application in AutoCAD. I can't seem to find the right connection string. Here is my latest attempt:
Set myConnection = New Connection
myConnection.Open "Provider=Microsoft OLE DB Provider For SQL Server; Data Source=xxxx;" & _
"UID=xxxx;" & _
"PWD=xxxx"
[DBNETLIB][ConnectionOpen (Connect().]SQL Server does not exist or access denied.
Since I can connect directly through dbconnect the problem must be with my connection string. Can anyone help?
TIA
Try conection string like this, not sure about
if this helps with your settings though:
connString = "Data Source=User\\SQLEXPRESS;Initial Catalog=XXX;Integrated Security=True;"
Or
connString = "Data Source=.\\SQLEXPRESS;Database=XXX.mdb;Persist Security Info=True;user id=XXX;password=;"
Not it.
This is remote SQL server so there has to be a data source. I'm trying to use the data source I've set up within dbconnect.
Thanks though
Sorry, I'm never worked with remote connection,
try to search for an answer on this branch^
http://forums.autodesk.com/t5/ASE-SQL-OLE-ADE/bd-p/16
