VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Custom Collection
9 REPLIES 9
Message 1 of 10
411 Views, 9 Replies
Custom Collection
Hi all,
I wish to make my own collection through VBA. Can I do it?
please, help me.
Rgds
Hector
9 REPLIES 9
Message 2 of 10
There are many types of collections...
What specifically?
Message 3 of 10
I want to build a collection based on drawing's objects, but of several types (circles, lines, polyline....) and layers.
Message 4 of 10
Here is a Collection sample. Check out a Scripting.Dictionary also.
To add the layers in the drawing just iterate ThisDrawing.Layers
similar to the way I did the Layouts.
[code]
Sub stub()
Dim coll As New Collection
Dim layout As AcadLayout
Dim ent As AcadEntity
'add all entities in all layouts to a collection
For Each layout In ThisDrawing.Layouts
For Each ent In layout.Block
coll.Add ent, ent.Handle
Next ent
Next layout
Dim entBlock As AcadBlock
'print all entities in the collection
'and the block they reside in
For Each ent In coll
Set entBlock = ThisDrawing.ObjectIdToObject(ent.OwnerID)
Debug.Print ent.ObjectName & " " & entBlock.Name
Next ent
End Sub
[/code]
gl - Paul
wrote in message news:5188195@discussion.autodesk.com...
Message 5 of 10
Paul, thank you very much. My problem is solved !!
Message 6 of 10
but how to use a collection,
if it is save as a part of a drawing and will be got ever since
thanks
"Paul Richardson" wrote in message
news:5188242@discussion.autodesk.com...
[code]
Sub stub()
Next ent
Next layout
Next ent
End Sub
[/code]
gl - Paul
Message 7 of 10
no a Collection is not saved with the drawing. An XRecord
is saved in the drawing, or you an use an external flat file or
database.
gl - Paul
"youngman" wrote in message
news:5188916@discussion.autodesk.com...
thanks
[code]
Sub stub()
Next ent
Next layout
Next ent
End Sub
[/code]
gl - Paul
Message 8 of 10
Thanks a lot.
so if i want to make use of collectionlike objects, i have to use,as you
said,
XRecord,xdata,dictionary,group , or , database ,
is that so,
best regards
news:5189008@discussion.autodesk.com...
database.
gl - Paul
thanks
[code]
Sub stub()
Next ent
Next layout
Next ent
End Sub
[/code]
gl - Paul
Message 9 of 10
yes...
Message 10 of 10
thanks
wrote in message news:5191711@discussion.autodesk.com...
yes...
”Boost
