I want to be able to create dxf files from within VBA but I am having problems opening the simple dxf files I create. I have attached an example. If I open the file in Outocad 2014 I get a 'Press enter to continue' prompt. When I hit enter it just opens a blank file.
If I try to insert the file as a block I get an 'invalid' prompt.
I assume there is something wrong with the format?
I'd be grateful for any advice here.
regards
Ron
I do understand the codes 10/20/30 as start point and 11/21/31 as end point, but I do not understand codes 12/22/32 ... and removing them works with _INSERT.
For descrption of a line defined in DXF look to >>>that manual<<<.
HTH, - alfred -
