VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Create layer from file
2 REPLIES 2
joh_richard
433 Views, 2 Replies
Hi
I need some help
I try to create list of layer from a files, but I don't understand the Do /While and I have a message error like missing  information for the creation of layer
Ex. of my list files
;Layername, colour,linetype
*Layer1
layer1a, 7, continuous
Layer1b,12,hidden
*layer2
layer2a,70,continous
Layer2b,82,hidden
The code I have from now
Dim sTemp As String
Dim sTemp1 As String
Dim nFile As Integer
Dim sLAYER As String
Dim sColor As String
Dim sLinetype As String
Dim objLayer As AcadLayer
sTemp = ListBox1.Text
nFile = FreeFile
Open sFile For Input As #nFile
    While Not EOF(nFile)
        Line Input #nFile, sTemp1
         If sTemp1 = "*" & sTemp Then
         Input #nFile, sLAYER, sColor, sLinetype
             Set objLayer = ThisDrawing.Layers.Add(sLAYER)
             objLayer.color = sColor
             objLayer.Linetype = sLinetype
        End If
    Wend
So is there someone could tell me how fix it
Thanks!
2 REPLIES 2
RICVBA
in reply to: joh_richard
I'm not good at reading files, so I can only suggest you to try the following
1) use the following for adding your layer
             On Error Resume Next
             If Err Then Set objLayer = ThisDrawing.Layers.Item(sLAYER)
             On Error GoTo 0
 so that if the layer already exists, you simply set your objLayer variable to it instead of adding it that would result in an error
2) use "objLayer.color = CInt(sColor)", to have an integer number assigned to color property, instead of a string
3) use "objLayer.Linetype = UCase(sLinetype)", to have always uppercase characters ("CONTINUOUS" instead of "continuous")
Finally as for the "While-Wend" loop, it looks like it should work but I'm not used at it and I'd code a "Do While-Loop" one as follows
Do While Not EOF(1)
Loop
hope what above helps
bye
joh_richard
in reply to: RICVBA
Thanks for your help!
”Boost
