VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
create break in a long pipe
8 REPLIES 8
Message 1 of 9
Pretty
536 Views, 8 Replies
I am new to VBA. I am trying to draw a very long pipe. Even after scaling properly, the pipe does not fit in the paperspace.
I want to put a break in the pipe. But the dimensioning has to show the actual length of the pipe and not the broken length.
How to draw the break symbol using VBA? How to do the dimensioning after you insert a break.
I hope the question is clear. Please help.
Thanks in advance,
Pretty
8 REPLIES 8
Message 2 of 9
in reply to: Pretty
Hi, Pretty
Not sure about this will be draw correctly
to your standars
Read comments inside the code
Change to your suit
Let me know if something wrong there
HTH
Fatty
~'J'~
Message 3 of 9
arcticad
in reply to: Pretty
I would simply have the pipe someplace else in modelspace then use a field to reference the value and put that value on the "broken" pipe
(defun botsbuildbots() (botsbuildbots))
Message 4 of 9
Pretty
in reply to: Pretty
Hey Fatty,
Thanks so much. It just works perfect!! and is exactly what I am trying to do. I am new to this field and it is so nice to get help.
Thank you again,
Pretty
Message 5 of 9
Pretty
in reply to: Pretty
Thanks for your reply. I did not understand well what you are trying to say.
Pretty
Message 6 of 9
Pretty
in reply to: Pretty
Hey Fatty,
Thank you again,
Pretty
Message 7 of 9
arcticad
in reply to: Pretty
Pretty,
I was talking about using custom fields, (smart text). You can select a value from another object and have it displayed in a text box someplace else.
You could draw your object and then have another copy of the object. Then reference the dimensions from the first object.
Message 8 of 9
Pretty
in reply to: Pretty
Hi arcticad,
Now I understand by what you meant by drawing somewhere else in modelspace. I will try it out and let you know.
Thanks for clarifying.
Pretty
Message 9 of 9
in reply to: Pretty
Hi, Pretty
Glad to help
I think it's a time to learn some VBA basics
Here is a good place where you can get
the help on this way
Happy computing 🙂
Fatty
~'J'~
”Boost
