VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Compare block attributes
5 REPLIES 5
tdaniel14
330 Views, 5 Replies
What i'm trying to do is loop through each block in a drawing, get the 3 attributes, compare the attributes to a row in an excel file, then import the excel information into the block.
What would be the best way to get the blocks and compare the attributes?
5 REPLIES 5
in reply to: tdaniel14
just for the record: a block is a definition of a group of elements, stored in a tablerecord, an inserted block in the drawing is called a blockreference, which is the same as an insert. attributes are stored with the reference, not in the block. try it: you can move attributes with the grips without moving the insert. if you redefine the block with the attributes in a different place, the existing attributes will stay in the old place.
so find the inserts in your drawing, check if they have atts an read their tags and values. Place then in a redim preserve variable, and compare them later on to your excel-sheet. Put the appropiate objectid in that datastructure so you can easily indentfy the right insert.
tdaniel14
thanks for the reply
cadtown
Do you have just one target attributed block to search for or many of them in each dwg file ?
tdaniel14
This particular drawing has 1500 blockreferences could be more or less.
Each has 3 attributes i need to compare with multiple rows of the excel sheet.
The excel sheet rows will vary from 5 to 150 and each row will have 3 values.
I'm not so into Excel, rather use a database for lists of objects with several attributes, the same way in fact Autocad has organized its objects.
Doesn't matter how many references you have in the drawing as long as you have enough memory...
Start off (Acad-VBA) by defining an structure:
Type att
Tag as String
Text as String
End Type
Type BlockAttribs
ObjectID as Long
Atts() as Att
End Type
'then declare the variable as an Array
Dim BA() as BlockAttribs
Public Sub Main
Dim obj as AcadObject
Dim blref as AcadBlockReference
Dim atts as Variant
Dim n as Integer
n=0
Dim i as Integer
For each obj in Thisdrawing.ModelSpace
if obj.ObjectName="AcDbBlockReference" then
set blref=obj
if blref.Name="WANTED NAME" then
Redim Preserve BA(n)
BA(n).ObjectID=blref.ObjectId
if blref.HasAttributes=True then
set atts=blref.GetAttributes
for i=LBound(atts) to UBound(atts)
Redim Preserve BGA(n).Att(i)
BGA(n).Att(i).Tag=atts(i).TagString
BGA(n).Att(i).Text=atts(i).TextString
next
end if ''HasAttributes
n=n+1 ''ready for the next one
end if ''if name is ok
end if ''if blockcref
Next
End Sub
You will get a global var BA. Edited by: lucaso on Mar 23, 2009 9:39 PM
”Boost
