VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
check if polyline is higher than the size of layout
3 REPLIES 3
imagination_s
393 Views, 3 Replies
Hellow Everyone,
I have a  problem geting information if a polyline is higer then the layout size using autocad 2008 vba
The picture below shows what i mean
Please Help
Thankyou very much
3 REPLIES 3
I would first verify the extents of the rectangle and the polyline, and in a seconed step (if necessary) check vertex-by-vertex of the polyline if it's within the rectangle or outside the rectangle.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
norman.yuan
in reply to: imagination_s
Froom your previous post, it looks like you want to get the portion of a polyline in modelspace that can bee seen through a paperspace viewport.
Because the view in paperspace viewport can be scaled, twisted, you need to project the viewport border into modelspace to actually know the intersection points the polyline with the viewport border (in modelspace), then you can proceed to find the portion(s) of polyline seeable through the paperspace viewport.
So, your code need to do these:
1. select a paperspace viewport in interest;
2. find the viewport's size (width, height). Things can get complicated if the viewport is clipped with a non-rectangular shape. You may want to work with rectangular viewport as starter;
3. translate coordinates of 4 corners of the viewport into modelspace coordinates. so you can construct a rectangle polygon in modelspace, representing the modelspace area that can be seen through the paperspace viewport; You use AcadUtility.TranslateCoordinate() to translate the coordinates;
4. Now you can use IntesectWith(0 to get points where the polyline and the rectangle meets;
5. According to the intersection points, you search through the vertices of the polygon one by one to determine which portion of the polyline is inside the rectangle.
Following code shows an sample from step 1 to 3. You should be able to work out the rest, based on previous code I showed:
Option Explicit
Public Sub DrawVPortInModelSpace()
  ''Make sure it is in paperspace
  If ThisDrawing.ActiveSpace <> acPaperSpace Then
    MsgBox "Not in PaperSpace!", vbCritical
    Exit Sub
  End If
  ThisDrawing.MSpace = False
  ''Pick the view port polygon
  Dim ent As AcadEntity
  Dim pt As Variant
  On Error Resume Next
  ThisDrawing.Utility.GetEntity _
    ent, pt, vbCr & "Pick a viewprot border:"
  If ent Is Nothing Then Exit Sub
  On Error GoTo 0
  Dim vPort As AcadPViewport
  If TypeOf ent Is AcadPViewport Then
    Set vPort = ent
    DrawVPortInModel vPort
  End If
End Sub
Private Sub DrawVPortInModel(vPort As AcadPViewport)
  Dim vCentre As Variant
  Dim dWHalf As Double
  Dim dHHalf As Double
  Dim dScale As Double
  vCentre = vPort.Center
  dWHalf = vPort.Width / 2#
  dHHalf = vPort.Height / 2#
  dScale = 1 / vPort.CustomScale
  ThisDrawing.MSpace = True
  ThisDrawing.ActivePViewport = vPort
  Dim mCentre As Variant
  mCentre = ThisDrawing.Utility.TranslateCoordinates( _
        vCentre, acPaperSpaceDCS, acDisplayDCS, 0)
        mCentre, acDisplayDCS, acWorld, 0)
  '' Calculate polygon's lower-left corner and
  '' upper-right corner in modelspace
  Dim llCorner(0 To 2) As Double
  Dim urCorner(0 To 2) As Double
  llCorner(0) = mCentre(0) - (dWHalf * dScale)
  llCorner(1) = mCentre(1) - (dHHalf * dScale)
  llCorner(2) = 0#
  urCorner(0) = mCentre(0) + (dWHalf * dScale)
  urCorner(1) = mCentre(1) + (dHHalf * dScale)
  urCorner(2) = 0#
  DrawPolygonInModel llCorner, urCorner
End Sub
Private Sub DrawPolygonInModel(llCorner As Variant, urCorner As Variant)
  Dim polygon As AcadLWPolyline
  Dim coords(0 To 7) As Double
  ''Lower-left
  coords(0) = llCorner(0)
  coords(1) = llCorner(1)
  ''lower-right
  coords(2) = urCorner(0)
  coords(3) = llCorner(1)
  ''upper-right
  coords(4) = urCorner(0)
  coords(5) = urCorner(1)
  ''upper-left
  coords(6) = llCorner(0)
  coords(7) = urCorner(1)
  Set polygon = ThisDrawing.ModelSpace.AddLightWeightPolyline(coords)
  polygon.Closed = True
  polygon.Update
End Sub
Norman Yuan
Drive CAD With Code
imagination_s
in reply to: norman.yuan
Thankyou again for your help and Repplys
Couldn't done without your help
So Thankyou so much 🙂
”Boost
