Show only
Search instead for
I've wrote some code to batch print all the layout in
a drawing but, but i would like to print them through acrobat distiller using the name of the layout as the file name.
Thanks for your answer, I did not instantiated the Distiller object. I'm really a newbie with vba , I was able to print all my layout to a normal printer but when i tried to use the distiller I had to specify the name for each layout (50+). what i would like to do use the name of the layout as pdf name.
this the code that I've wrote ::
Sub PlotLayouts()
Dim Plot As AcadPlot
Dim AddedLayouts() As String
Dim LayoutList As Variant
Dim Layout As AcadLayout
Dim ArraySize As Integer
Dim BatchCount As Integer
For Each Layout In ThisDrawing.Layouts
If Layout.Name <> "Model" Then
ArraySize = ArraySize + 1
End If
Next
ReDim AddedLayouts(1 To ArraySize)
ArraySize = 0
AddedLayouts(ArraySize) = Layout.Name
End If
Next
If ArraySize = 0 Then Exit Sub
LayoutList = AddedLayouts
Set Plot = ThisDrawing.Plot
Plot.StartBatchMode ArraySize
For BatchCount = 1 To ArraySize
Plot.SetLayoutsToPlot LayoutList
Plot.PlotToDevice "C:\Program Files\Acad2000\plotters\pdf-dwg.pc3"
Next
end sub
