VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Changing Color of object using autocad Vba
1 REPLY 1
ajoshi1967
6722 Views, 1 Reply
Dear All
I used following code to change the colour of Line in AutoCAD 2013 32-bit.
Sub Ch4_ColorCircle()
    Dim color As New AcadAcCmColor
    Call color.SetRGB(80, 100, 244)
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    circleObj.TrueColor = color
    ZoomAll
End Sub
The program worked nicely.
but when I ran the program in AutoCAD 2013 64-bit I got following message for code (Call color.SetRGB(80, 100, 244))
Automation Error
%1 is not a valid Win32 application.
Can any help solve this problem. Is this problem related to 64-bit AutoCAD.
1 REPLY 1
if you change your first line with Dim .... to that:
    Dim color As AcadAcCmColor
    Set color = ThisDrawing.Application.GetInterfaceObject("AutoCAD.AcCmColor.19")
Does that work?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
