VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Change Block Attribute Insertion point
7 REPLIES 7
Message 1 of 8
2306 Views, 7 Replies
In need to modify an attributes insertion point in an existing block (ACAD 2002)
(part code)
CurrInsrt = attr.InsertionPoint
insrt(0) = 100 + CurrInsrt(0)
insrt(1) = 100+ CurrInsrt(1)
insrt(2) = 0 + CurrInsrt(2)
attr.InsertionPoint= insrt
dosen't work and I can't figure out why. CurrInsrt is a variant, insrt is a double(0 to 2)
I saw the entry about using TextAlignmentPoint but if the attribute is rotated it is rotated around the insertion point not the TextAlignmentPoint
phill
7 REPLIES 7
Message 2 of 8
Bryco
Do it in cad first then code it.
If you are updating the block, you still have to reinsert all the blockreferences to see the new attribute positions, just like doing it in cad.If you are finding each blockreference and moving the att without updating the block, you better read up on matricies
Message 3 of 8
Yes I am updating it with attr.update.
But as far as I cantell I am essentially following the example in the help file
I have tested the other lines and all seems correct.
"attr.InsertionPoint= insrt
attr.update"
is not working and I can't figure out why
Message 4 of 8
Are you modifying the block definition or each individual block reference. If you are modifying the def only then in AutoCAD try the command ATTSYNC.
Regards - Nathan
Message 5 of 8
I am actually just trying to change each block reference attribute individually.
the way I have been doing it is by using the move command to reposition the attribute.
Is the insertionpoint property a global thing ie applies to the block not the block referenece? that would mean i'd have to sync it for the changes to take affect. In which case I won't use it because the changes will be applied to all blocks
Phill
Message 6 of 8
arcticad
I'm sure there is an easier way but this has worked fine for me.
You just need to set the xyz of the attribute. You do not use move.
since you can't reference the insertionpoint with att.insertionpoint(0) i just run it through a simple convertion
dim pt(2) as double
pt(0) = convertpt(att.insertionpoint,0)
pt(1) = convertpt(att.insertionpoint,1)
pt(2) = convertpt(att.insertionpoint,2)
then you can just add say an x distance to the value or whatever to move the attributes around.
then assign the new point to your att.insertionpoint
[code]
Function convertpt(pt, pos) As Variant
Dim k As Integer
Dim newpt(2) As Double
For Each item In pt
If j = pos Then
k = k + 1
If k = 1 Then
convertpt = item
If k = 2 Then
convertpt = item
If k = 3 Then
convertpt = item
j = j + 1
Next
End Function
[/code]
(defun botsbuildbots() (botsbuildbots))
Message 7 of 8
Hi Poflynn
I am not sure but try to regenerate your drawing at end of your code might be it work.
Message 8 of 8
Bryco
Guess I was wrong about matricies for the 2d stuff
[code]Sub moveatt(B As AcadBlockReference, Dist As Double)
Dim Att As AcadAttributeReference
Dim Atts, Pt
Dim Rot As Double
Set B = EntSel
Atts = B.GetAttributes
Set Att = Atts(0)
' Att.LockPosition check that
Rot = Att.Rotation
Pt = Att.TextAlignmentPoint
Pt(0) = Pt(0) + Cos(Rot) * Dist
Pt(1) = Pt(1) + Sin(Rot) * Dist
Att.TextAlignmentPoint = Pt
End Sub
[/code]
”Boost
