Hi
I have a model who's UCS is rotated about the Z axis.
This routine inserts a block & draws a line from the insert point of it.
Why does the insertpoint & Addline require the original Ipt but the Getpoint use the translated pointUCS1?
Have I got the UCS's round the right way within the TranslateCoordinates command?
I've never got my head around it & get the result by trial & error.
Hope you can help
Dave F.
Sub DrawBubble(HorV As String)
Dim IPt As Variant, LPt As Variant
Dim Ang As ACAD_ANGLE
Dim Pt2 As Variant
Dim pointUCS1 As Variant
IPt = ThisDrawing.Utility.GetPoint(, "Insert Point: ") ' insert point
Ang = dtr(360) - ThisDrawing.GetVariable("viewtwist")
ThisDrawing.ModelSpace.InsertBlock IPt, "C:\dwgs\Blocks\bh\grid2.dwg", 100, 100, 100, Ang
pointUCS1 = ThisDrawing.Utility.TranslateCoordinates(IPt, acWorld, acUCS, False)
Pt2 = ThisDrawing.Utility.GetPoint(pointUCS1, "End Point of Line: ")
ThisDrawing.ModelSpace.AddLine IPt, Pt2
End Sub
