VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Block Z value from Civil 3d Surface
2 REPLIES 2
Mikexlt
636 Views, 2 Replies
I can't quite get this to work.
I  am placing blocks onto a civil 3d surface and running the following code to set the Z valve of the Block from the surface. I can get the elev value, but can't get to assign it to the z value for the block. What am i missing?
 For Each NodeEnt In SelNode
                Set node = SelNode.Item(i)
           nodex = NodeEnt.InsertionPoint(0)
                 nodeY = NodeEnt.InsertionPoint(1)
             elev = surf.FindElevationAtXY(nodex, nodeY)
       NodeEnt.InsertionPoint(2) = elev
               NodeEnt.Update
           If elev = 0 Then
          ' MsgBox "Node " & "N" & N & " at X= " & Format(nodeX, "0.00") & "  Y=" & Format(nodeY, "0.00") & vbCrLf & " has no elevation"
           Error.TextBox1.Text = Error.TextBox1.Text & "Node " & "N" & n & " at X= " & nodex & "  Y=" & nodeY & " has no elevation" & vbCrLf
        ERRSTATUS = 1
           End If
        ' NodeEnt.GetXData "mdc_Hyd", 1070, xdata
          'elevation = elev + NodeDepth
 elevation = elev
         Epanet.TextBox4.Text = vbCrLf & Epanet.TextBox4.Text & "N" & n & vbTab & elevation & vbCrLf
                 'i = i + 1
             n = n + 1
  Next NodeEnt
2 REPLIES 2
Alfred.NESWADBA
in reply to: Mikexlt
you can't just modify the array item at index 2 of the object's insertion point.
Create a new variable with 3 doubles, assign them x/y/new z and assign that variable to the insertion point of the blockreference:
   Dim tNewPnt(2) as double
   'get the x/y/new z values
   tNewPnt(0) = NodeEnt.InsertionPoint(0)
   tNewPnt(1) = NodeEnt.InsertionPoint(1)
   tNewPnt(2) = surf.FindElevationAtXY(tNewPnt(0), tNewPnt(1))
   'assign that new point to the blockref's insertion point
   NodeEnt..InsertionPoint = tNewPnt
Not tried, just out of remembering, hopefully that remembering works ok 😉
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Mikexlt
in reply to: Alfred.NESWADBA
Thanks Alfred,
Works fine now.
Mike
”Boost
