Thank you Matt.
I had tried that, but it still didn't quite take, so I had asked in customization, and suggestion over there was to use (chr 34). Basically same as what you're showing, but I create a variable first.
But you were right though, I needed the extra quotes, works nice now.
Thanks!
"Matt W" wrote in message news:40a8d5e1$1_3@newsprd01...
Forget the last post...
It needs to be "\"".
I'm stuck in the world of VBA.
Sorry...
(defun C:ScriptTest ( / scrpt)
(setq scrpt (open "e:/temp/script.scr" "w"))
(write-line (strcat "\"" "Long file name" "\"") scrpt)
(close scrpt)
(princ)
Matt W
There are 3 kinds of people:
Those who can count, and those who can't.
"Matt W" wrote in message news:40a8d4dd_1@newsprd01...
it's been a while but I believe this will work...
Note the sets of (3) quotes.
(write-line (strcat """ LongFileName """) script-name)
Matt W
"Jason Wilder" wrote in message news:40a8d3f3$1_3@newsprd01...
Um, mind refreshing my memory on how to add a quote - " - to each end of my path name and put that into a script file?
"Matt W" wrote in message news:40a8d258_1@newsprd01...
Can you say "too much caffeine"??? Someone's a little "click-happy" this morning...
If you put quotes around your file names, you should be able to process them with you batch plotting program.
I.E. "C:\temp\long file name\first floor steel.dwg"
Matt W
"Matt W" wrote in message news:40a8d1db$1_3@newsprd01...
> Matt W
> news:40a7b4a1_2@newsprd01...
> > I'm looking for advice and suggestions as to whether or not batch plotting
> > with VBA is a good idea, or even practical?
> > We don't necessarily have large plot jobs, most of our projects are 8-15
> > sheets in total. I have an old routine written that will allow the user
> to
> > select files through the (dos_msgbox) - DosLib - and then process the
> > returned list through a routine that will build a script file. This works
> > great, BUT it requires that the file names and paths not have any spaces
> in
> > them. Unfortunately, a great deal of our folders have spaces, and
> renaming
> > them would be more of a pain because then all the pathed xref's get messed
> > up.
> > Anyway, I think that gives the picture of my delimma. Now, realizing that
> > VBA will process paths w/ spaces in them. I was thinking of using my
> > previous routine to create a TXT file rather than a SCR file, and then
> > initiate a VBA routine that will process the file against a defined plot
> > routine.
> > Or are there different methods I could consider in regard to VBA?
> > Thanks for any advice.
