I don't know if that can help, but in one project I process the BeginSave
event, I too have problems with AutoSave. The way I do it is that I "filter"
the events by comparing the name of the actual document with the name coming
from the argument of BeginSave:
If they are the same
It is a "regular" save
If they are not the same
If extension is "SV$"
It is AutoSave, forget it
If extension is "a$c"
CopyClip is involved, forget it
Else
It is SaveAs
Hope it helps.
Gilles
"thenov" wrote in message
news:12918139.1097598030814.JavaMail.jive@jiveforum1.autodesk.com...
> I have written a BeginSave event to process some things before every save.
It works great except for 1 thing. When the AutoSave function kicks in it
does the AutoSave multiple times. Some times 10, 15, or 20 time with the
same AutoSave File Name. I think AutoCAD is locked up but in reality it is
the AutoSave running multiple times that is causing the problem.
> Anyone have any ideas? Do I have to reset some timer to get the AutoSave
to function properly. The SAVETIME system variable remains unchanged at 20.
Please let me know.
