For what it's worth.....
Have you implemented any type of error handling? I don't know if this will work or not but you could try something like Err.Source to help pinpoint the source of the error.
Matt W
There are 3 kinds of people:
Those who can count, and those who can't.
"DaveP" wrote in message news:40ad0451$1_3@newsprd01...
> I'm doing this inside AutoCAD 2002, using VBA.
> I guess I could post my code, but I'd have to stick the entire DVB file up
> here, as well as the LISP code (and several supporting enivronment
> variables) along with it. The code runs fine on my laptop, though. Its
> just that somewhere there's a dll or an ocx that other people have a
> different version of. If you guys (who have been very helpful, thank you)
> don't have the same apps installed, you'd be looking for Referneces that I'm
> not haviong problems with. Its most likely either my DWGThumbnail.ocx or a
> VoloView control. Since there's only one version of the DWGThumbnail, and a
> whole bunch of different versions of the VoloView program floating around,
> it's most likely the VoloView.
> My whole point was, though, why can't VBA just tell you which "Variable uses
> an Automation type not supported in Visual Basic"? It knows where its
> blowing up. Why keep it a secret from me? After all, I created it!
> "Yves" wrote in message news:40acfd83$1_1@newsprd01...
> > If in the "non-working" station you don't have a "missing" in the
> > references, you should look in the controls in any forms, that might not
> > exist in other computers.
> > Wait, are you using VB or VBA?
> > Can you post a part of that code?
> > "DaveP" a écrit dans le message de
> > news:40acfc1c$1_3@newsprd01...
> > > Yes, we all have the same AutoCAD (2002), but what I'm trying to find
> out
> > is
> > > WHICH other objects I need to look at to see if I've got the right
> > version.
> > > It would be handy if AutoCAD (or probably Microsoft) would at least tell
> > me
> > > which "Variable uses an Automation type not supported in Visual Basic"
> so
> > I
> > > don't have to go slogging through every dll & ocx in my project.
> > > "Yves" wrote in message news:40acfafa_2@newsprd01...
> > > > Is all computers running the same version of Autocad?
> > > > If you are using other objects, like Office in your DVB, are everyone
> on
> > > the
> > > > same version.
> > > > news:40acf736$1_2@newsprd01...
> > > > > I'm getting an error message that reads:
> > > > > Compile error:
> > > > > This DVB works on my machine, but not others. I assume I've got an
> > > > > additional, or a newer version of some sort of dll or ocx, but how
> do
> > I
> > > > tell
> > > > > which one? I've looked at the References, and it can find a file
> for
> > > all
> > > > of
> > > > > them. The error message appears as soon as I try to run the DVB
> > Macro.
> > > > No
> > > > > hint as to where the problem is, or which variable uses an
> > Auto...blah,
> > > > > blah, blah.
> > > > > TIA
