I have come to a road block, I am for a lost of how to connect the information that i type into textboxs and to change the values of dimensional constraint parameters ex. d1 d2 d3
Can you please help me
AutoCAD 2010 introduced the Parameter/Constraint stuff, but no API was exposed. AutoCAD2011, however, exposed the API in ObjectARX and ObjectARX .NET API. It is unfortunately there is no COM API exposed that you can use in VBA programming.
If you need to do programming on the Parameter/Constraint thing, you need to use Acad2011 and do either VC++ or .NET. No VBA (it dies anyway after Acad2011).
Is there any vba code out there that can at least get me to a finished product im trying to automaticly draw my detailed drawing with a userform or excel?
Can i modify this code to do it.
Sub PromptForDims()
Dim DimName As String, DimValue As Double
DimName = InputBox("Enter Parametric Dim name:")
DimValue = InputBox("Enter Parametric Dim value:")
Call EditParametricDim(DimName, DimValue)
End Sub
Private Sub EditParametricDim(ByVal ParamName As String, ByVal ParaValue As Double)
On Error Resume Next
Dim oDoc As AcadDocument, oEnity As Object, oRotDim As Object
Set oDoc = ThisDrawing
For Each oEnity In oDoc.ModelSpace
Set oRotDim = oEnity
If CStr(oRotDim.DimConstrName) = ParamName Then
If Err.Number = 0 Then oRotDim.DimConstrExpression = ParaValue: Exit For
If Err.Number = 438 Then
'Object doesn't have DimConstr objects
Err.Clear
Else
'Some other error
If Err.Number > 0 Then GoTo ErrHandler
Next
Exit Sub
ErrHandler: MsgBox Err.Description
End Sub
is there any possibility to edit the user variables in parametric manager by Autocad VBA.If yes please help me in this issue.
Can you please post your VisualLisp routine?
I would like to know which variables to look for and hopefully adapt it to vba.
Thanks a bunch!
I'll show you a quick sample of what I found. I still don't know if this works for "User Parameters," but it definitely works for dimensional constraints.:
Dim objfind As AcadObject
Dim dimrotfind As AcadDimRotated
Dim enclosuretopblock As AcadBlock
Set enclosuretopblock = acaddoc(1).Database.Blocks("ENCLOSURE")
For Each objfind In enclosuretopblock If TypeOf objfind Is AcadDimRotated Then Set dimrotfind = objfind If dimrotfind.DimConstrName = "D_ENC_LEN" Then dimrotfind.DimConstrExpression = enclen ElseIf dimrotfind.DimConstrName = "D_ENC_WID" Then dimrotfind.DimConstrExpression = encwid ElseIf dimrotfind.DimConstrName = "D_WT" Then dimrotfind.DimConstrExpression = wallthk End If End If Next
enclen, encwid, wallthk are doubles.
if you could tell me exactly what you're trying to do, I could try to fill you in. I still don't know about reading/writing what autocad calls "User Parameters," but as far as dimensional contraints, custom properties, and all that go, I could probably answer your question.
Well i have made a dynamic block
I got the Length, width added with a linear parameter
With my vba.program i should be able to modify these parameters.
I have a code written, but i get a error : " invalid input"
i get the error on this line : " oDblkProp.Value = txtHoogte"
On a other forum they told me i had to change it into "oDblkProp.Value = txtHoogte.Text"
But is still does not work
this is my code:
Public txtHoogte as double
Dim objBlok1 As AcadBlockReference
Dim strPath As String
Dim oprops As Variant
Dim oDblkProp As AcadDynamicBlockReferenceProperty
Dim i As Integer
dblInvoegpunt(0) = 0: dblInvoegpunt(1) = 0: dblInvoegpunt(2) = 0
Set objBlok1 = ThisDrawing.ModelSpace.InsertBlock(dblInvoegpunt, "C:\Autocad\Definitieve blocks\1.Onderkast\1.Vooraanzichten\Niet Beplakt\Vooraanzicht.NB.Doorlopende Stijlen.dwg", 1#, 1#, 1#, 0#)
If objBlok1.IsDynamicBlock Then
oprops = objBlok1.GetDynamicBlockProperties
For i = 0 To UBound(oprops)
Set oDblkProp = oprops(i)
If oDblkProp.PropertyName = "Hoogte" Then
'oDblkProp.Value = "txtHoogte" 'Hoogte van de kast
Exit For
Next
Do you know what i have to do to fix this error?
I need to do the same thing with other parameters
thanks
Sorry about that last empty post. Hit post on accident.
If you copy/pasted directly from your vba window, your issue is the quotes around "txtHoogte." You don't want those there. The way you have it now indicates that you'd like to set that property (that can only be numeric, not letters) to be the word "txtHoogte" when in reality, you want it to be the value of the variable txtHoogte. Just take out the quotes on this line and you should be fine: 'oDblkProp.Value = "txtHoogte" 'Hoogte van de kast
The final format should be oDblkProp.Value = txtHoogte 'Hoogte van de kast
haha is that Swedish?
sorry, I'm mistaken. didn't see the next line there. But I'm not seeing where you give txtHoogte a value. if txtHoogte is a text box, take out the Dim line for txtHoogte (you don't have to declare existing text boxes) and for VBA, you'll have to use txtHoogte.Caption I believe.
However, if you're trying to use txtHoogte as a variable, you'll have to assign it a value before you use it. Something like txtHoogte = tboxHoogte.Caption.
So if that's a text box, here's your new code:
Dim i As Integer
oDblkProp.Value = txtHoogte.Caption
Exit For
Next
__________________________________________________________________________
and if txtHoogte is supposed to be a variable, this is your new code (note: you will have to have a text box called "TBoxHoogte" on your form):
Dim i As Integer
txtHoogte = TBoxHoogte.Caption
Exit For
Next
I'm not sure if you're new to this or not, but make sure you run code to regenerate your drawing at the end or you may not see any changes.
Good luck.
(by the way, I think Autodesk's website may have corrected something it thought was HTML in there, I just can't tell what it changed.)
Well i tryed what you send me but the error keeps coming back. i don't know what it is .. i checked everything a 100 times...
I also tryed this :" txtHoogte = CDbl(Val(frmKast.txtHoogte.Value))"
Its very strange if i run the program and i enter in my form 1500 the txtHoogte is 1500 but. Ill add a printscreen of what i mean.
Dim i As Integer
Exit For
Next
I still hope somebody can help me.
