VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Autocad VBA: Microsoft Common Dialog Control 6.0 (SP6)
1 REPLY 1
1682 Views, 1 Reply
I have both Autocad 2008 and 2010 installed on my PC. I am not sure but I can't see this(see Subject) reference in Autocad 2010 reference list but it is there in my 2008 version. I want to use this in one of my userform that I am creating.
Is there any subtitute that I can use or something similar because I want to use one of my macro that I made for Autocad 2008 in 2010 version as well, I couldn't find an easier way then coping(impoting and expoting) the modules and stuff.
-Devesh
1 REPLY 1
AubelecBE
hello
create a new module with a name.
put your macro in this module.
call this sub with the name of module.
so after this you can export this module and import in you new programm.
it is named : library.
(you can directly edit this export with notepad. (use full for renamed un name or string)
it it works for the dialog too.
”Boost
