Well, I tested it in AutoCAD 2004, and had exactly the same results !!
I then drew some lines, circles, ellipses, hatches, and tested the undo/redo
many times, without any problem whatsoever.
I checked that the dimscale value was still 1.8
I then dimension linear and then dimcontinue and IT WORKED !!!
What the heck is happening here ???
Saludos,
Ing. Jorge Jimenez
SICAD S.A., Costa Rica
"Tony Tanzillo" wrote in message
news:40aa7457_1@newsprd01...
> Ignoring this problem for a moment, and with all
> the normal code you're using in the Begin/EndCommand
> events, have you tested this with AutoCAD 2004, and
> verified that it does not affect the user's ability
> to use UNDO/REDO without restriction?
> http://www.caddzone.com
> AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005
> http://www.acadxtabs.com
> "Jorge Jimenez" wrote in message
news:40aa7244_1@newsprd01...
> > Thanks alot for the suggestion, but it didn't work.
> > DIMCONTINUE with a DIMSCALE value of 1.8 still goes bezerk !!
> > This is what I did:
> > 1. Dimension the acad application variable Acapp without events
> > 2. Dimension the Adoc variable as autocad.acaddocument WITH events
> > 3. Place the change layer code to the Begin and End command events of
the
> > Adoc
> > This is the class as I have it now:
> > VERSION 1.0 CLASS
> > BEGIN
> > MultiUse = -1 'True
> > Persistable = 0 'NotPersistable
> > DataBindingBehavior = 0 'vbNone
> > DataSourceBehavior = 0 'vbNone
> > MTSTransactionMode = 0 'NotAnMTSObject
> > END
> > Attribute VB_Name = "Comandos"
> > Attribute VB_GlobalNameSpace = False
> > Attribute VB_Creatable = True
> > Attribute VB_PredeclaredId = False
> > Attribute VB_Exposed = True
> > 'Public WithEvents Acapp As AutoCAD.AcadApplication
> > Public acapp As AutoCAD.AcadApplication
> > Public WithEvents Adoc As AutoCAD.AcadDocument
> > Attribute Adoc.VB_VarHelpID = -1
> > Public Function Iniciar(tAcadapp As AutoCAD.AcadApplication) As Long
> > Dim myform As Form
> > Set acapp = tAcadapp
> > Set Adoc = acapp.ActiveDocument
> > dimlayer = "DimLayer"
> > dimcolor = 1
> > End Function
> > Private Sub Adoc_BeginCommand(ByVal CommandName As String)
> > Dim mylayer As AutoCAD.AcadLayer
> > Select Case CommandName
> > Case "DIMLINEAR", "DIMALIGNED", "DIMORDINATE", "DIMRADIUS",
> > "DIMDIAMETER", "DIMANGULAR", "DIMBASELINE", "DIMCONTINUE", "QLEADER",
> > "LEADER"
> > Set Tactivelayer = acapp.ActiveDocument.ActiveLayer
> > Set mylayer = acapp.ActiveDocument.Layers.Add(dimlayer)
> > mylayer.Color = dimcolor
> > mylayer.Lock = False
> > mylayer.Freeze = False
> > mylayer.LayerOn = True
> > acapp.ActiveDocument.ActiveLayer = mylayer
> > End Select
> > End Sub
> > Private Sub Adoc_EndCommand(ByVal CommandName As String)
> > Dim temp As String
> > "LEADER"
> > acapp.ActiveDocument.ActiveLayer = Tactivelayer
> > End Select
> > End Sub
> > Saludos,
> > Ing. Jorge Jimenez
> > news:40aa5d17$1_3@newsprd01...
> > > My next suggestion is to try using the Document's
> > > BeginCommand and EndCommand events, rather than
> > > the Application's
> > news:40aa5790$1_2@newsprd01...
> > > > I commented out the Select Case statement entirely
> > > > and the wierd DIMCONTINUE behavior IS STILL HAPPENING !!
> > > > There is no code in the begin and end command events
> > > > except a dim.
> > > > Now this is very strange indeed.!!
> > > > Saludos,
> > > > Ing. Jorge Jimenez
> > > > news:40aa4eb6_3@newsprd01...
> > > > > What happens if you comment out the Select Case
> > > > > statement entirely?
> > > > news:40aa405e_2@newsprd01...
> > > > > > Thank for the reply.
> > > > > > I have no doubt you are correct about that being a
> > > > > > cause for many problems.
> > > > > > But in this case, I'm not so sure about this.
> > > > > > I have included the same DLL, but with the code
> > > > > > for changing the layer commented out.
> > > > > > So inside the begin and end command events
> > > > > > there is ONLY a SELECT CASE which does
> > > > > > NOTHING.
> > > > > > So, if I'm not mistaken, of course, the document state
> > > > > > should not change due to the select case statement.
> > > > > > And still, AutoCAD presents the same weird behavior.
> > > > > > Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
> > > > > > (sorry, phony e-mail, SPAM made me do it)
> > > > > > news:40aa396a_3@newsprd01...
> > > > > > > Jorge - It may be any change the the document state
> > > > > > > that triggers the problem. For example, doing nothing
> > > > > > > but calling the Select() method, or one of its variants,
> > > > > > > can change the document state (the Previous selection
> > > > > > > set is changed).
> > > > > > news:40a9816f$1_1@newsprd01...
> > > > > > > > Thanks for the reply Tony.
> > > > > > > > Actually, the real dll does not change the layer at the
> > > > > > > > begincommand event, it stores a count of the entities
> > > > > > > > at the moment the command begins, and then compares
> > > > > > > > that count with the count at the endcommand event.
> > > > > > > > Then it changes the layer of the new entities.
> > > > > > > > The problems happens no matter how this is done.
> > > > > > > > I agree with you about the cache factor, but the fact that
> > > > > > > > it only happens with certain values of the dimscale variable
> > > > > > > > makes this behavior quite different.
> > > > > > > > I made this test dll as simple as possible to make sure
> > > > > > > > everyone could see the behavior without thinking it
> > > > > > > > could be some other event going on.
> > > > > > > > I even took out the change layer code in the events, and
> > > > > > > > the problem persited.
> > > > > > > > news:40a979d4$1_3@newsprd01...
> > > > > > > > > Jorge - The fact that this happens is not something
> > > > > > > > > I would find shocking.
> > > > > > > > > Generally, making changes to the database in events
> > > > > > > > > like the ones you're using, can lead to unpredicable
> > > > > > > > > behavior. One reason why (but not necessarily the one
> > > > > > > > > that is causing this particular problem), is because
> > > > > > > > > many AutoCAD commands, especially older ones, locally
> > > > > > > > > cache things like the active layer and other relevant
> > > > > > > > > data used in the creation of new entities. So, in fact,
> > > > > > > > > changing the active layer after the fact, can actually
> > > > > > > > > be ignored by some commands because they may have
> > > > > > > > > already made a local copy of the value of the CLAYER
> > > > > > > > > system variable.
> > > > > > > > > Of course, it can depend on the mechanics of the
> > > > > > > > > command, and when the reactor/event is fired, but
> > > > > > > > > generally, doing the kind of things you're doing
> > > > > > > > > entails the risk of unpredicable behavior, on a
> > > > > > > > > command-specific basis.
message
> > > > > > > > news:40a96ad2_2@newsprd01...
> > > > > > > > > > Can anyone confirm the following bug and where it's
coming
> > from
> > > > > > > > > > 1. Unzip the included "DLLTest.dll" and "DLLTest.lsp"
in a
> > temp
> > > > dir
> > > > > > > > > > 2. Regsvr32 DLLTest.dll
> > > > > > > > > > 3. Load AutoCAD 2000-2002 (it also happens with 2004 and
> > 2005,
> > > > just
> > > > > > > > change
> > > > > > > > > > the reference lib in the dll project and recompile)
> > > > > > > > > > 4. Select "Start from Scratch", "metric"
> > > > > > > > > > 5. Load the lisp "DLLtest.lsp"
> > > > > > > > > > 6. write DIMSCALE, and enter a value of 1.8
> > > > > > > > > > 7. Use the DIMENSION menu and select LINEAR. Dim any two
> > points
> > > > > > > > > > 8. Use the DIMENSION menu and select CONTINUE. Move the
> > cursor
> > > > and
> > > > > > > > watch
> > > > > > > > > > the dimcontinue command go bezerk !!
> > > > > > > > > > Now, if CANCEL and enter a DIMSCALE value of 1.0 to 1.5,
the
> > > > > > dimcontinue
> > > > > > > > > > works again !!
> > > > > > > > > > The zip includes the source for the VB6 dlltest.dll
> > > > > > > > > > TIA
