VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Attaching dimensions to a Dimension Style
2 REPLIES 2
RalphBrown99
364 Views, 2 Replies
Hi:
I have a group of dimension objects gather up by a selection set (objSS). I can screen each one one of these dimension by the lines
Dim objDimStyle As AcadDimStyle
For Each objDimension In objSS
Next
How is possible to assign the property Dim Style to each one of my objDimension to an Style that I have already created?
I can not find this property available for my objDimension
Thanks in advance
Rafael
2 REPLIES 2
Hallex
in reply to: RalphBrown99
Cast objects explicitly, always
Dim oEnt as AcadEntity
dim objDimension as AcadDimension
For Each oEnt In objSS
set  objDimension=oent
If Typeof  objDimension is AcadDimRotated then
dim acDimRot as AcadDimRotatedDimension
set acDimRot=objDimension
'then something similar:
acdimRot.Style="myNewStyle"
else if Typeof  objDimension is AcadDimAligned then
dim acDimAlign as AcabDimAlignedDimension
set acDimAlign=objDimension
acDimAlign.Style="myNewOtherStyle"
Next
ETC,
Sorry, Just from the top of my head without VBA Editor,
digg deeper inside all dimension types then,
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex
in reply to: Hallex
well, here is the code, see how it works for you
Option Explicit
Public Sub ch_dimstyle()
     Dim gpCode(0) As Integer
     Dim dataValue(0) As Variant
     Dim dxfcode, dxfdata
     Dim oEnt As AcadEntity
     Dim oDim As AcadDimension
     Dim setObj As AcadSelectionSet
     Dim setColl As AcadSelectionSets
     Dim setName As String
     Dim objEnt As AcadEntity
     Dim stName As String
     stName = "MyNewDimStyle"
     If Not IsDimStyleExist(stName) Then
     MsgBox "Dimstyle does not exist, create one before..."
     Exit Sub
          On Error GoTo Err_Control
         gpCode(0) = 0: dataValue(0) = "DIMENSION"
       dxfcode = gpCode: dxfdata = dataValue
     setName = "$DIMENSION$"
     With ThisDrawing
          Set setColl = .SelectionSets
          For Each setObj In setColl
               If setObj.Name = setName Then
                    .SelectionSets.Item(setName).Delete
                    Exit For
          Next
          Set setObj = .SelectionSets.Add(setName)
     End With
     setObj.SelectOnScreen dxfcode, dxfdata
     setObj.Highlight True
     MsgBox "Selected: " & CStr(setObj.Count) & " objects"
 For Each oEnt In setObj
 Set oDim = oEnt
        If TypeOf oDim Is AcadDimRotated Then
        Dim acDimRot As AcadDimRotated
        Set acDimRot = oDim
        acDimRot.styleName = stName
        acDimRot.Update
        ElseIf TypeOf oDim Is AcadDimAligned Then
        Dim acDimAlign As AcadDimAligned
        Set acDimAlign = oDim
        acDimAlign.styleName = stName
        acDimAlign.Update
         ElseIf TypeOf oDim Is AcadDimDiametric Then
        Dim acDimDia As AcadDimDiametric
        Set acDimDia = oDim
        acDimDia.styleName = stName
        acDimDia.Update
        ElseIf TypeOf oDim Is AcadDimRadial Then
        Dim acDimRad As AcadDimRadial
        Set acDimRad = oDim
        acDimRad.styleName = stName
        acDimRad.Update
        'ElseIf TypeOf oDim Is ETC...
        'Else ...
    Next
    ThisDrawing.Regen acActiveViewport
Err_Control:
If Err.Number <> 0 Then
    MsgBox Err.Description
End Sub
Function IsDimStyleExist(styleName As String) As Boolean
IsDimStyleExist = False
Dim oDimSt As AcadDimStyle
On Error Resume Next
   For Each oDimSt In ThisDrawing.DimStyles
   If StrComp(oDimSt.Name, styleName, vbTextCompare) = 0 Then
   IsDimStyleExist = True
   Exit For
   Next
End Function
~'J'~
”Boost
